Seems like I have without noticing on my RPi 4. Seems to work fine, but I don't really use mine for anything advanced (WiFi + DAC over USB).Has anyone upgraded their RPi to 6.18 yet?
It's supposed to be updated through apt package manager, but mine hasn't. I wonder if I need to use the rpi-update in order to get it.Seems like I have without noticing on my RPi 4. Seems to work fine, but I don't really use mine for anything advanced (WiFi + DAC over USB).
Curious to know hy you went to all the trouble of getting the horribly lossy Bluetooth protocol to work when you could easily use lossless Chromecast or Airplay etc?Hey everyone,
Apologies if this was already posted in the 140 pages of discussion but I just finished wrestling with Rpi5, Dac8x and Hifime HR23 and wanted to share tips with anyone interested. My case is living room active speakers with TV and phones as the sources, connecting via BT:
I don't know about the "horribly lossy" part, I thought LDAC is supposed to be pretty good?Curious to know hy you went to all the trouble of getting the horribly lossy Bluetooth protocol to work when you could easily use lossless Chromecast or Airplay etc?
Apologies if my tone was a bit curt. All Bluetooth protocols are lossy, but LDAC is higher bandwidth than most. Even AptX Lossless is mostly lossy.I don't know about the "horribly lossy" part, I thought LDAC is supposed to be pretty good?
As for casting over wifi, I have no experience with those, a quick google suggested much higher latency and more difficult setup, please inform that's not the case
Hey everyone,
Feeling fantastic at the moment, can share details if anyone's interested
- I spent 2 weeks trying to make the Pi accept a bluetooth stream directly, managed to handshake AptxHD but did not resolve buffer/resampling issues. I guess there's a reason bluetooth isn't even mentioned on the tutorial
- The tutorial states that Hifime HR23 does not work with Rpi5. It does if you connect it via hub. This was suggested by the manufacturer and seems to be true so far.
- I use a FIIO BR13 device as a BT receiver. This solved the Unfortunately, it doesn't do true 96khz upsampling, just frequency doubling. So this doesn't solve the resampling problem. And this seems to be impossible to solve in software too - tried all sorts of loopback tricks to make Alsa or PipeWire do the automatic resampling. It works but the problem is HR23 doesn't announce a sample rate change if it happens on the fly, so no way to reliably detect it.
- The tutorial recommends a hardware resampler, but I find using a dedicated DSP box just for this a bit wasteful. So I went with a brute force solution - I had an old DIR9001 SPDIF to I2s capture module. Connected that to the SPDIF OUT of BR13, LRCK to a GPIO pin of the Pi, a simple counter script and voila - hardware sample rate detector.
- Several days of python debugging with Gemini and I have a script that monitors the actual incoming sample rate and reconfigures CamillaDSP's upsampler to accept either 44.1 or 48kHz on the fly.
This is true. Spotify Connect and Google TV (the smart TV OS) killed my BT usage almost entirely. Instead of setting up BT connectivity, one should first see if he can set up a player that is remote controlled by mobile devices. Only if that's not possible, set up streaming from mobile device to the audio device.Apologies if my tone was a bit curt. All Bluetooth protocols are lossy, but LDAC is higher bandwidth than most. Even AptX Lossless is mostly lossy.
If your use case is streaming music from a phone/tablet/laptop around your home then you're much better off using Chromecast (Google Android, Chromium etc), Airplay (Apple IOS, OSX etc), or Slimproto (Logitech/Lyrion Squeezebox,Squeezelite etc) as they're true lossless that operate over IP (eg wifi, ethernet). The tutorial covers all three. In order of preference I'd recommend using Slimproto (if running a Lyrion server and using Rpi as an endpoint), then Chromecast, then Airplay, in that order, because Airplay doesn't support over 48KHz and neither it nor Chromecast support gapless. Also, Squeezelite uses SoX for resampling, which can produce much better results than Bluetooth or ALSA native resampling. See Archimago's post regarding this.
piCorePlayer is a very simple and easy way to get these working on a Rpi and you can use this script to very easily integrate CamillaDSP with it.
Yes, please.Feeling fantastic at the moment, can share details if anyone's interested
No worries, thanks for the tips. Given my use-case I'm not as worried about the whole lossy transmission aspect but it's nice knowing there is something to move to later.Apologies if my tone was a bit curt. All Bluetooth protocols are lossy, but LDAC is higher bandwidth than most. Even AptX Lossless is mostly lossy.
Totally understand, but I think the HR23 connected via hub bit would be useful even to beginnersThanks for sharing!
The tutorial is meant to be plug and play for those without any technical knowledge, so I've purposely avoided things like I2S interfacing.
To clarify, you are using the UR23 as a capture device and only using the DIR9001 module for rate detection? Are there any audible artifacts during rate changes or is it well behaved?
Michael
The script just counts interrupts over a measurement period, so in theory it can accept any samplerate. However my simple Python implementation, it does 96khz but has quite a few misses even on a Pi5. For 192khz I would seriously consider doing this in C or better yet - use a hardware counter.Yes, please.
Would it be difficult to modify the script to also accept 96k and 192k samplerates?
I use camilladsp-setrate, but it does not work with the latest version of CamillaDSP. Would you mind if I shared your solution with the developer of camilladsp-setrate?
with open(CONFIG_PATH, "r") as f:
config = yaml.safe_load(f)
# Dynamic chunksize allocation based on target input sample rate
target_chunksize = 4096 if target_rate in (88200, 96000) else 2048
config["devices"]["capture_samplerate"] = target_rate
config["devices"]["chunksize"] = target_chunksize
# Persist change to file
with open(CONFIG_PATH, "w") as f:
yaml.dump(config, f)
# Issue atomic re-configuration to CamillaDSP engine
ws = websocket.create_connection(CAMILLA_WS_URL, timeout=1.0)
ws.send(json.dumps({"SetConfigJson": json.dumps(config)}))
time.sleep(0.05)
ws.send('"Reload"')
ws.close()
print(f"[DSP] Successfully reloaded CamillaDSP engine (rate: {target_rate} Hz, chunksize: {target_chunksize})", flush=True)
How about official Raspberry Pi touch display?Hi all, what's the lowest system resource-consuming driver / interface solution for a small OLED monitor used to display basic camilladsp info using an rpi5?
I tried the SPI. route but it's not a real cpu saver...actually, it's still kind of eating alot, %-wise.
How about a small HDMI monitor?
Thanks!!
Jim
