2025-09-27 18:50:43.640483 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.648478 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.656491 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.664485 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.672482 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.680483 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:43.688483 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:50:56.392355 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:50:56.697429 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:50:56.698893 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:52:28.784455 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:52:29.090379 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:52:29.091845 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:01.672342 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:55:01.977275 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:55:18.220378 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:55:18.667047 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:55:21.958460 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:22.086829 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:22.600956 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:22.724105 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:23.022996 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:23.154006 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 18:55:28.072551 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:55:28.518103 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:55:49.444584 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:55:49.889483 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:56:14.320116 ERROR [src/processing.rs:132] Message channel error: receiving on a closed channel
2025-09-27 18:56:14.320309 INFO [src/bin.rs:373] Playback finished
2025-09-27 18:56:51.987359 WARN [src/processing.rs:97] Failed to build thread pool, error: The global thread pool has already been initialized.
2025-09-27 18:56:52.343955 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:57:17.672658 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 18:58:22.339640 INFO [src/alsadevice.rs:976] Capture device is stalled, processing is stalled
2025-09-27 18:58:22.444174 ERROR [src/processing.rs:132] Message channel error: receiving on a closed channel
2025-09-27 18:58:22.444535 INFO [src/bin.rs:373] Playback finished
2025-09-27 19:01:18.044679 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 19:03:11.977540 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 19:03:16.767501 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.769491 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.771493 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.775493 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.779494 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.783494 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.791494 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.795493 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.799530 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.801019 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:03:16.803096 WARN [src/alsadevice.rs:207] PB: write underrun, trying to recover. Error: ALSA function 'snd_pcm_writei' failed with error 'Broken pipe (32)'
2025-09-27 19:03:16.811161 WARN [src/alsadevice.rs:242] Prepare capture device
2025-09-27 19:03:16.812382 INFO [src/alsadevice.rs:561] PB: device stalled
2025-09-27 19:03:16.831416 INFO [src/alsadevice.rs:976] Capture device is stalled, processing is stalled
2025-09-27 19:03:16.831602 ERROR [src/bin.rs:314] Capture error: ALSA function 'snd_pcm_start' failed with error 'Broken pipe (32)'
2025-09-27 19:03:31.577624 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 19:13:51.219324 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 19:42:44.912509 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 19:42:55.885251 INFO [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2025-09-27 20:14:13.315306 WARN [src/alsadevice.rs:113] PB: Prepare playback after buffer underrun
2025-09-27 20:14:13.324177 WARN [src/alsadevice.rs:242] Prepare capture device
2025-09-27 20:14:13.344426 INFO [src/alsadevice.rs:976] Capture device is stalled, processing is stalled
2025-09-27 20:14:13.344642 ERROR [src/bin.rs:314] Capture error: ALSA function 'snd_pcm_start' failed with error 'Broken pipe (32)'
