- Thread Starter
- #2,421
Unfortunately no changes:
* set the rates to 44.1 kH everywhere (Wiim out, Camilla capture and samplerate)
* target level at 1536
* bypassed the filters
* playback at normal volume: buffer around 1500 no issues
* lower volume in Wiim app to 0/100, not pausing playback - lots of constant and quite loud noise , buffer goes down, but stays around 1400. No warnings in the log. After 1-2 minutes of this noise, capture device is stalled (so silence at last...) and CamillaDSP restarts just fine if I turn the volume up
* turn volume up to 1 - random noises, turn volume up in Wiim app to 2/100 - all good - silence... Like if S2 could not handle 0s stream
* and I know I am repeating myself, but this is the greatest mystery to me. 2 out of 3 toslink cables I have - behavior like above. 3rd cable - it is much better, there are random cracks at 0 volume, but with the other 2 it is non-stop crackling noise. Otherwise there is no difference in those 3 cables when playing music (not to my ears at least, and I would not expect much difference between toslink cables). So why they behave so differently in relation to silence and S2....
Maybe I just purchase one of the Rpi digihats with coaxial input (b
Interesting, do you still have issues with pausing? Or only when you reduce volume to 0/100 or 1/100?
I usually attenuate in CamillaDSP or a downstream DAC rather than upstream. But I can try sending an attenuated signal to the S2 and see if I have issues. I also just tried the S2 with the RPi5 as most of my testing has been with the RPi4 and it seems fine.
It is rare but I've run across SPDIF sources that do not play nicely with all receivers. It is certainly possible that the Wiim and the S2 do not work together but the Wiim and Marantz could still be fine.
Michael
