- Thread Starter
- #2,281
@mdsimon2 : Thanks for adding the update commands to your tutorial. Before I give it a go: do the V2 config files need any changes made? I thought not, but recent posts on DIYaudio have me confused.
I haven't fully updated the guide for v3. It seems like v2 configurations with simple routing and no filters come over fine, but if you have filters they do not.
The process to convert to v3 isn't entirely straight forward. You need to make sure the configuration in the GUI is blank by clicking "New Blank Config" and then click "Import Config" -> "Upload new config file" -> CamillaDSP Config -> select your config and check all the boxes -> "Import". This loads the configuration in to the GUI but then you still need to save it using the disk button. After that it should show as a valid config and be labeled as version 3.
Michael
