2024-09-10 01:17:14.923587 INFO [src/
bin.rs:683] CamillaDSP version 2.0.3
2024-09-10 01:17:14.923951 INFO [src/
bin.rs:684] Running on linux, aarch64
2024-09-10 01:17:15.006062 WARN [src/
audiodevice.rs:523] Needless 1:1 sample rate conversion active. Not needed since enable_rate_adjust=False
2024-09-10 01:17:15.026158 INFO [src/
alsadevice.rs:648] Capture device supports rate adjust
2024-09-10 01:17:15.026348 WARN [src/
alsadevice.rs:650] Needless 1:1 sample rate conversion active. Not needed since capture device supports rate adjust
2024-09-10 01:17:15.066506 INFO [src/
alsadevice.rs:799] Capture device is stalled, processing is stalled
2024-09-10 08:54:34.053322 INFO [src/
alsadevice.rs:142] PB: Starting playback from Prepared state
2024-09-10 08:55:01.728970 INFO [src/
2024-09-10 08:57:18.963064 WARN [src/
alsadevice.rs:138] PB: Prepare playback after buffer underrun
2024-09-10 08:57:38.991190 INFO [src/
2024-09-10 09:08:51.531276 WARN [src/
2024-09-10 09:09:01.436775 INFO [src/
2024-09-10 09:13:34.784152 WARN [src/
2024-09-10 09:23:57.961971 WARN [src/
alsadevice.rs:216] PB: write error, trying to recover. Error: ALSA function 'snd_pcm_writei' failed with error 'EPIPE: Broken pipe'
2024-09-10 09:33:56.723952 WARN [src/
2024-09-10 09:43:37.348041 INFO [src/
2024-09-10 09:43:37.606658 WARN [src/
2024-09-10 09:43:58.648501 INFO [src/
2024-09-10 09:45:37.633829 WARN [src/
2024-09-10 09:55:13.546716 WARN [src/
2024-09-10 09:59:34.592292 INFO [src/
2024-09-10 09:59:34.871812 WARN [src/
2024-09-10 09:59:50.879046 INFO [src/
2024-09-10 10:45:16.132122 WARN [src/
2024-09-10 10:55:53.419487 WARN [src/
