ROUTER FOR ROON
G
Georgeadv
The company changed the modem you previously had that gave no problems with this one that does produce them?
The company provides a modem router which i had no problem but had poor range and wws basic
I added on that the asus and i have drop
Outs
xaviescacs
La Garriga, Barcelona
Outs
Drops in Wifi or Internet?
From this sentence
my current connection is ads and I am using a modem provided by my isp connected router that I have which however regularly drops connection. its an asus
I understood the asus is provided by the company, sorry.
I have the adsl modem directly connected to the router which is connected to hegel h190
"Connected" means wifi or ethernet?
G
Georgeadv
From this sentence
Its connected with ethernet
Its the internet that goes out - not the wifi signal
Although even when its own , its slow…. For example i have my tv connected via ethernet.. via wifi netflix shows for some time lower res
Forgot to mention that i live in an apartment block.. dont know if this is relevant to wifi connectivity
Snoopy
Turn off 2.4ghz WiFi and use only 5ghz.
I have around 14 visible 2.4ghz networks around me. At to that Bluetooth stuff that messes with the same frequency range.
G
Georgeadv
If i use 5gz range is limited :p dead end :)
Timcognito
NorCal
mSpot
Timcognito
NorCal
It wasn't mentioned here, but the OP is in Europe.
My Bad, but as a DSL user out in rural California, DSL is the only option. So OP may have look outside of his building to get a solution. Thanks mSpot for pointing this out. Thought Europe has the highest internet speeds and bandwidth?
G
Georgeadv
where I live there is only 1 that rents out the lines to others....
we are getting fiber within next year....
Snoopy
I'm in a rural town and 300mbit DSL (unlimited) is pretty much basic.
Fiber and cable is available as well.
