ROTEL RCD-965BX, add DAC or upgrade to a newer CD player?
DeaconJohn
Greetings,
I have a ROTEL RCD-965BX, which I bought in the 1990s. Should I add a DAC or upgrade to a newer CD player? I saw a thread here about the unique DAC implementation Rotel used in these models. My guess is that the newer DAC chips are much better than one 30 years old. The ROTEL RCD-965BX does not have an optical output, only a coaxial, and the tray does not always open correctly.
It's a perfectly good CD player - what are you expecting from changing it, if it still works?
Maybe it's just cosmetically aged on your shelf? What's your real motivation?
Perhaps you could rip your CDs on a PC and play back the FLACs on a streamer/DAC from the network or an SSD drive/USB stick? Perhaps you can use the CD player's optical or co-ax out to a DAC to feed your amp?
Top Tip. Speakers are the biggest thing in changing the sound of things...
If it weren't for the fact that ...and the tray does not always open correctly.
If the problem gets worse and if you, @DeaconJohn can't fix it yourself:
(Gemini AI)
Then, throw it away or sell it for spare parts. It’s not worth paying a professional repairer to fix it—unless, of course, it holds sentimental value.
Fortunately, a new CD player isn't that expensive. The only reason I’d use an external DAC with one would be to get volume control functionality.
The tray not always opening at that age is most likely either a stretched/hardened belt or a limit switch needing a bath in contact cleaner. There's a very high chance this will be a <5$ repair if you are comfortable doing it yourself.
Welcome. Your best SINAD from a CD player is 96dB undithered.
Today's best SINAD DACs are around 120dB if memory serves.
So we're around 24dB less noise/distortion than we were before.
Can you hear a difference between 96dB and 120dB SINAD?
Likely not. I can't. This is the music floor we're talking about. If you're a trained musician or mastering engineer, better chance.
That doesn't mean you shouldn't upgrade. Mechanical CD players have a limited shelf life. Parts are getting harder to source. I had a few players I really liked, but it seemed as though they all started malfunctioning at the same time. So I decided mechanical players were not the way to go for me.
I ripped all my CDs to FLAC files, and sold my CDs and CD players. Now all my music resides on an Eversolo DMP-A6 streamer, 112dB SINAD through the RCA outs if memory serves.
Those FLAC files don't sound any better or worse through the Eversolo. I can't tell the difference between the CD and the FLAC version. It's all the same to me.
@DeaconJohn Check this out—luckily, there was a video about it, for the Rotel RCD-965BX specifically:)
