Perhaps, but Vincia does have subwoofers.the Ascend Sierra-1 V2 are nice, but:
What motivates the Vincia is a lack of clarity in the fortissimo passages, so more emissive surface area is needed.
Since the woofer in the Ascend is identical to the one in the PMC, compared to the 7.5-inch woofer of the Buchardts,
which represents an emissive surface 2.25 times larger, the choice is obvious.
Something played or sung very loudly, with high dynamics, especially if you crank up the volume, that in itself demands a lot from your hi-fi system. You really ought to check if the setup—amp and speakers—can handle high SPL (while maintaining reasonably low distortion).
Buchardts 7.5-inch woofer might have slightly higher sensitivity then the Sierra-1 V2 woofer but it’s hardly an SPL monster. That woofer—albeit a really good one— is rated for 70 watts of power handling:
7½″ SATORI MW19P-8 / Paper - Sbacoustics
Vented aerodynamic cast aluminium chassis for optimum strength and low compression, proprietary cone material with EGYPTIAN PAPYRUS™ fibres made in-house.
If you like playing highly dynamic music at deafening volumes, you should look into high-power-handling PA bass drivers/woofers paired with compression drivers.
Maybe high-sensitivity horn speakers, and so on. I know that’s not an option for the Vincia, but I thought I’d mention it anyway.
By the way, horn speakers the size of a refrigerator (or larger) aren't for everyone. These are the compromises one is forced to make—including regarding one's wallet.
(In my case, I also have to consider the neighbors in the apartment complex.)
