Rotel RB-870BX vs class D (hypex/Purifi…)
.My question then is: what advantages have brought more than thirty years of technology development on amplifiers?
Regarding your question about the last thirty years—if we look at Class D amplifiers:
-Better frequency response.
-Lower distortion, especially in the high-frequency range.
-A wider selection leading to increased competition and lower prices.
Class D design guru Bruno Putzeys has stated that the biggest advantage of Class D (provided the amps are transparent and don't audibly color the sound) is that they can be made physically smaller than Class AB—not to mention the massive Class A units.
In other words, a Class D amplifier can deliver equal or greater power than Class AB or A designs while being more compact.
3. - In post #33 @melomane13 suggests to put the crossover frequency (speakers x subwoofer) between 100 and 200 Hz. Could this improve the response considering that the curve of GB1 PMCs (https://www.soundstagenetwork.com/measurements/pmc_gb1/) at about 165 Hz has a reduction of 10 dB?
I also recommended sealing the mouth of the transmission line, which turns the speaker into a sealed enclosure and thereby eliminates the 150 Hz phase cancellation caused by the transmission line.
Thank you, I find your suggestions interesting. I will certainly do these tests in a few weeks, when I will be home. I will make my impressions known. How do I close the TL ports? What materials?
A wooden panel fixed with dense foam double-sided adhesive tape at least 1 mm thick.
By lightly pressing the panel against the speaker cabinet, the foam will conform to the micro-imperfections of the wood and completely block any air passage.
It is reversible, so it's fine for running a test — not a permanent solution, it's strictly a reversible test method.
I also recommend taking measurements before and after
And listen in mono to compare the "sealed" and original speaker.
Some more suggestions:
A sealed speaker needs to be as airtight as possible. Not for nothing that it is called sealed. :)
Cover the exhaust/port with a sawn piece of wood. If you don't want to glue or screw this piece of wood—whether it's MDF, plywood, particleboard, or whatever you have on hand—you can use clamps to hold it in place over the exhaust opening. Place some kind of seal, such as a paper gasket or a thin sheet of rubber, between the cut-out wood piece and the speaker.
Based on the answers received so far, I can make three considerations:
1. - Everyone considers the replacement of the Rotel with more modern class D amps unconvincing. My question then is: what advantages have brought more than thirty years of technology development on amplifiers? Maybe it only served to keep production costs low? Are the improvements in measurements not appreciable by the human ear?
2. - Many suggest changing the speakers. What should I pay attention to by looking at the charts? For example: what are the significant differences between the PMC GB1 (https://www.soundstagenetwork.com/measurements/pmc_gb1/) and those of KEF R5 Meta (https://www.spinorama.org/speakers/KEF R5 Meta/ErinsAudioCorner/index_eac.html)?
Here is as close of a comparison as I can figure out how to show. The black curves are the PMC speaker FR on-axis, 15 and 30 degs off axis. Overlayed, the colored curves are the same type of data from the KEF R5 Meta, with the exception being it is on-axis, 10 and 30 legs off axis. I'm ignoring the data below 200, as I'm not clear what the source of the big dip at 150 on the PMC. Note how much variation there is in FR from the PMC compared to the relatively linear frequency response of the KEF.
Here is as close of a comparison as I can figure out how to show. The black curves are the PMC speaker FR on-axis, 15 and 30 degs off axis. Overlayed, the colored curves are the same type of data from the KEF R5 Meta, with the exception being it is on-axis, 10 and 30 legs off axis. I'm ignoring the data below 200, as I'm not clear what the source of the big dip at 150 on the PMC. Not how much variation there is in FR from the PMC compared to the relatively linear frequency response of the KEF.
Thank you, very informative answer. I can only correct that dip at 150 Hz a little with Wiim’s room correction. From 200 hz up it might be easier to correct.
You can't correct dips with a DSP, because those are cancellations caused by phase shift.
Digital amplifier technology has not progressed much in twenty years. I made a comparison of the new Topping Mini 300 against the twenty-year-old Panasonic D-class AV receiver (I put it on YouTube). According to my findings, class D amplifiers still sound somewhat harsh on high tones and higher mids. A good AB decade-old AB amplifier still sounds more natural in classical music. The class D amplifier impresses with a lot of details at first listen, but after a long listen it becomes tiring and unnatural.
We have now access at type D amplification, which is less expensive, much smaller, much more frugal in electricity, hardly get warm.
So if one of those aspect is key for someone that is progress.
If not, then any amp from 30 years ago, you might already have or can get for cheap will sound just as good.
Amplification is not an issue and has not been an issue for more than 30 years. Transparent enough to fool any of us.
That is a lot of subjective opinions induced by sighted bias (I was thinking of some other words than opinion, but I am in a good mood today), if only you could back it up with objective facts, that would be interesting.
Why would your Topping Mini 300 have a specific "sound"? From what I can see, it isn't load-dependent, so the frequency response remains flat and unaffected. If it has enough power for your needs, it should "sound" the way a good class AB amp does—that is: nothing at all.
Topping Mini 300 amplifies the signal without coloring it. It also maintains low distortion in the high frequencies (which can be—and has historically been—an Achilles' heel for some class D amps).
There is no guarantee at all that is a good idea.
I am not in support of increasing the crossover frequency to the subwoofer especially as OP does not have two subs to locate close to each main speaker. This also does not address the very uneven mid and high frequency response of the main speakers.
I missed that you wrote that.You beat me to it.:)
There are so many misconceptions. Even though the image below is a joke, there are likely people who believe this anyway:
Class D is NOT digital.
And there is no evidence to support your claims about the sound of class D amps apart from the subjectively biased views of the audiophile scene.
I missed that you wrote that. You beat me to it.:)
No worries, I think it is worth repeating, funny enough, I think it might take more than just our reply to convince new comers, but, hopefully, like it did for me a few years back, the message come trough and a new audio horizon opens up.
If you believe what audiofools parrot to justify their massive spending on overpriced heating appliances, you are biased. And very well able to make your brain think you heard something.
I see that a lot of knowledgeable audio experts have come to me, who undoubtedly know better than I do what I hear.:)
So to clarify: To MY ears, purely subjectively, MY AB amplifiers sound a little different than MY Class D amplifiers. I have put on YouTube for comparison recordings of MY two Class D amplifiers of very different ages. Everyone can see for themselves that they sound a little different.
So the message to the experts is: Either I have bad amplifiers. Or bad ears. Or both are bad.:)
And I apologize for calling Class D digital. It was in connection with the Panasonic receiver, which calls its Class D a fully digital amplifier, since it transforms the PCM digital input into PWM amplification without DA conversion. Topping works differently, of course.:)
In this forum, I see many knowledgeable people willing to offer advice. I'm taking advantage of this opportunity: I need advice on whether to replace my power amplifier Rotel RB-870BX with a class D (hypex/Purifi…).
Current system (as of 2025)
- Streamer-DAC-Preamp: WiiM Ultra
- Power amp: Rotel RB-870BX (100W; purchased in 1991)
- Speakers: 2 PMC GB1 (tower transmission line; purchased in 2004)
- Subwoofer: KEF Kube 12B
Listening room: approximately 180 m3
Speaker position: near the wall
Listening point: 2.5 m from center of speakers
Level: 75 dB approx
Music genres: classical (50%), jazz, pop
My hearing: I have the normal hearing impairments of a 78-year-old and I don't use hearing aids.
What would I like to improve?
I recently introduced the streamer and the subwoofer (with an 80 Hz crossover) and have done some interesting experiments with WiiM's room correction. Compared to my previous system, listening to symphonic music has improved significantly, as I can now appreciate even full orchestral performances, even if the sound remains a little confusing (before, only small ensembles were satisfactory). I'm wondering if you think listening to symphonic music would improve further if I replaced the old Rotel, and what amplifier (and power) I could use instead.
I have no intention of replacing the speakers (small footprint), which for 20 years have been in a position that makes them acceptable to other family members.
The budget should be no more than €1,000-1,500, staying below that if possible.
Thank you.
Here’s what I would do if I were in your shoes: sell your Rotel RB-870BX and your PMC GB1s. Add the proceeds to your budget and buy a combo solution—that is, active speakers. I can promise you that for the money you’re spending on those speakers, you can get some seriously good active ones—speakers that deliver genuine, high-quality hi-fi sound.:)
Sure, there is no guarantee at all, but
1) the owner reports congestion in fortissimos—not a timbre issue—and as you said, the off-axis curves look consistent, so there’s a chance the speaker could be EQ’d successfully, at zero cost using the WiiM.
3) the operation is reversible, and would help validate the diagnostic as a last resort, with the only risk being that the subwoofer might become localizable.
In that case, the owner can choose whether to add a second subwoofer or change the speakers...
Many people think the "D" in Class D stands for "digital.", it doesn't.But there is no such thing as a digital amplifier.
(Why is it necessary to go through a DAC (unless you're going old-school analog, like vinyl) before feeding the signal into a Class D amplifier?)
Passive speakers cannot convert a digital signal into sound—just as we cannot do so with our ears. We cannot hear digitally because our ears do not have built-in DACs.
