Hifi for life .
- Joined
- Feb 25, 2026
- Messages
- 71
- Likes
- 2
Hello !
Can anyone confirm if you use the left and right pre out for stereo subs ??
Why is there 2 mono sub outputs?
Would this be suitable for Minidsp flex at later stage?
Connecting subs to Minidsp flex and the speakers with the Rotel.
I understand Rotel has not set fixed low pass filter -meaning you’d need subs like SB2000 PRO.
I’ve also been considering the Marantz stereos 70. It has 2 sub outputs (unfortunately not independent.) You’re out luck … But 2 SVS subs or 1 with Marantz now pass filter which is from 40-240 Hz. The 70 has pre out also .
Can I then connect the Ultra streamer pre amp ? As an active crossover . This has to be easier option for me .
Yamaha AS701 is beginning to be flaky.
At times no sound from coax . At times it turns it self off while switching it on ! ! !
The speaker terminals are not of best quality-never has. They’ve always been bit loses while connecting one cable , but each one has begun to move lot more then before .
Rotel is on sale at moment.
I do not need any of extra features it provides, hence I’ve considered used AS1200.
New Marantz Model 50. If someone could tell me if Minidsp of some can be connected to the above amps mentioned
Model 50 with the Wiim Pre amp streamer… I’ve read the Model 50 is more powerful then it’s conservative watts .
I’ve tried different coax cables and tried wiggling the cable , the sound is stable . So my guess is the Yamaha own digital chip freezes. I’m no expert.
It’s not my streamer .
