If you like Rotel’s sound, you should explore the 1576MKII. I can tell you it sounds better than the HTP-1 (even after Dirac measurements), the Rotel out of the box sounds very good, maybe its synergy with the Rotel amp I have idk. That being said, I think the HTP-1 has some extra features but, at the end of the day it’s all about sound quality. Also, one thing I noticed on the HTP-1 the sound is just much ”lower” where I need to crank it up higher yet it still doesn’t feel as rich as the Rotel even at lower levels. I’m leaning Rotel right now.I currently have the Rotel RSP-1582 in my system and considering the HTP-1, the MKII or the NAD M17 V2. After reading all the excellent reviews and comments on this fabulous site I suspect one should wait until a company releases a product that measures and preforms like it should for the price point. I prefer Audio over video and really like the sound of the Rotel in my room over that of my previous Marantz 8802A or the Integra DHC 80.3. Always chasing components that I can afford that will improve my listening experiences. I've found my DVD-A collection (over 100), to be the best sounding source although the come SACD and Blue-ray mixes are wonderful.
Looking forward to hearing from more members on this thread and thanks to all who support this forum.
When you say significantly increase your budget for multi-channel music listening, are you referring only to pre/pros? Do you have any suggestions?When it comes to HT processors, forget "audiophile sound quality" and focus on setup and ease of use. Ultimately, if better quality sound is completely lost on frustratingly impossible room setup & bad bass management because you can't figure out the badly designed UI put together by people with NO CLUE about interface design, what's the point? I like how Monoprice's web based UI is set up and now their integration of Dirac and Dirac bass management is pretty solid. The reason I say forget about "audiophile" sound quality is because the home theater experience overwhelms the senses with bright flashing distracting visuals and HEAVY impact mid-bass which in my opinion completely masks any "audiophile" differences - this is why critical listening often is done in complete darkness to focus your hearing on the music. Good home theater experience instead should focus on the things that content creators spend all their time on: immersive spatial effects (Atmos or Auro3D) for true film immersion. Obviously, if you plan to use this pre/pro for multi-channel music listening too, then you are going to have to raise your budget significantly in order to nail down that last 2-3% of audio performance.
Though I don’t have Atmos speakers, setting ATV4k to DD5.1 works fine.
Some nice results but the panther says a lot as does the conclusion.Please read the whole review a do not look at he panthers only.
