WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Are you sure there is a version of Roon that will run on this? Generally for Synology and the like, someone adapts the server software for the platform.
You can probably use this as your library and run the server/core software on a separate PC. This is what I do. The music sits on the NAS and is networked to a separate Roon dedicated PC.
Did you check the minimum system system requirements for Room OS? You typically require more CPU, RAM & I/O than many typical NAS systems come with. Assuming the OS on the NAS is Windows you'll require at least an i3 processor and 8GB RAM and also recommends SSD storage for the Roon OS itself: https://help.roonlabs.com/portal/en/kb/articles/faq-what-are-the-minimum-requirements
Most Room users install Room OS/Roon Core on PC pointing to their music library on NAS
What wicky says. I have a much more powerful NAS than the one described above (I have a Synology DS1819+ with extra Ram and 2x400 GB SSD Cache) and even I don't run Roon server (Roon Core) on that NAS although it is (on paper) able to do so. I run Roon on a dedicated NUC (fanless) and use the NAS only to store my library.
A NUC is name brand of a small form-factor or 'mini' PC by Intel https://www.intel.co.uk/content/www/uk/en/products/details/nuc/mini-pcs.html These are often preferred for Roon and media server applications because they are (usually) cheaper, less power hungry, and can be tucked away out of site somewhere. Another popular choice for these types of applications are Mac mini's.
It's worth noting that Roon has it's own DSP which it very useful additional functionality but it requires more resources than your typical NAS or Raspberry PI based media server/streamer.
A NUC is a mini computer (Next Unit of Computing), with few (or in the case of a fanless NUC, zero) moving parts. You can buy them ready-built with an Intel Corei5 or Corei7 cpu, a small SSD hard drive (say 128GB or 256GB) and 16 Gb of Ram. You install a special version of Roon called ROCK on the NUC (detailed instructions are available on the Roon website) or you can buy a NUC with ROCK pre-loaded if you shop around. Let em know if you need more info.
I'm surprised that nobody has asked this yet, but how exactly did it fail to install?
Not sure I can help much though. I'm not running ROON anywhere, but it's on my roadmap, after I replace my 15 year old QNAP, and I'm interested in replacing it with something smaller/cheaper than the 6-bay NAS I have now.
The resource requirement is debatable. A Pi 4 is quite capable of doing a fair bit of DSP as Moode's CamillaDSP support or the Volumio BruteFIR and CamillaDSP plugins demonstrate, and for many people it will be more than enough. They will run out of processing capability earlier than current x96_64 processors, but you probably have to be doing something unusual to reach that limit.
The Roon sight has the Nucleus, advertised as the best way to use Roon. I had the NAS and decided to try it.
I think I will just use the iMac alone…works ok and no more hassle.
Intel NUCs have been a blessing for our home devices on the Microsoft turf-side of the equation.
I have a NUC8 and a NUC10 (of the Intel i7 line).
Beware, as my results to use it as a part of an HTPC is not having the results I expected from the newer NUC10, as it cannot handle video streams that are H.265 and/or 4K video. There are some eGPUs (external graphics card/cages) made for such needs but the costs are not justifiable for my needs (IMHO).
I have a MyCloud EX2 Ultra (dual drive) and Roon refuses to load. Roon and NUCs like each other.
You are quite right, I should have really said Roon requires these resources, in fact it's a combination of DSP, mutliroom and other functionality they provide.
Everything you ever wanted in a music server is here. Navigate your music in a truly unique way, with easy access to concert dates, artist bios, lyrics, and more.
Even so its hardware requirements seem very steep compared to daphile (so LMS, doing multiroom and DSP for as many locally connected players as you have, but not video or multichannel). I assume they're covering themselves for the exceptional loads like converting multichannel dsd to pcm before doing a monstrously long convolution, rather than just being spectacularly inefficient.
