WeekendWarrior
- Joined
- Jul 14, 2022
- Messages
- 145
- Likes
- 149
I’m planning to improve my 2.2 system by adding a multi-channel DAC to allow better subwoofer integration. I know a miniDSP could handle this, but I’d like to work through the setup myself. I’m considering using MSO, @OCA GSonic, HPF and LPF filters, with Roon controlling everything.
I asked Google Gemini about this, and it suggested creating a Roon configuration file to define how audio is routed to each DAC channel. I hadn’t heard of this approach before, so I wondered what the ASR experts knew about this.
Here’s an example for one sub channel (there's a similar one for the other channels):
# Channel 3: Subwoofer 1 (Compensated for single-ended physical signal loss)
1 1 [SINGLE_ENDED_MULTIPLIER] 0.0
MSO_Sub1.wav
0
0.0
XO_LowPass.wav
0
0.0
This contains routing information, filters to be applied and additional info such as gain adjustment (i.e. “single_ended_multiplier” because I’d be connecting my single ended subs to a balanced output thus losing 6dB volume).
All the instructions together with the “.wav” files would be zipped and loaded into Roon’s convolution engine.
Wow, I hadn’t been aware that Roon could do this, nor could I find much info within Roon. So my question is can Roon really do this, and does anyone have experience of using it?
MSO_Sub1.wav
0
0.0
XO_LowPass.wav
0
0.0
