WalkingBrass
- Joined
- Jun 9, 2025
- Messages
- 24
- Likes
- 28
- Thread Starter
- #21
Thanks for all your insights !
Anyway, the measurements I shared are from the positioning shown in the first photo. I also plan to take measurements with the speakers placed around the TV and bookshelf to see if that gives me a better baseline for EQ.
Also, in most setup photos I've seen, the distance between the speakers doesn't look that wide. Is it better to aim for an equilateral triangle (placing the right speaker to the right of the bookshelf), or should I narrow the distance for an isosceles triangle (placing the speaker to the left of the bookshelf) ?
One last question: when I ran the room correction with the WiiM app, it EQ'd way more than just two frequencies (I can show the correction it gave me). Should I also aim for a more detailed EQ too ?
Do you think that will be enough ? I've read that the Lintons need quite a bit more breathing room.leave about 10 cm to the front wall for bass reflex pipes.
