Room measurements - How to proceed?
Slotenpiloot
Hi everyone,
I’m looking for some advice on tweaking my setup using my existing gear.
My Current Setup & Room:
  • Speakers: Visaton Concorde MK III
  • DAC/DSP: Topping D50 III (using its 10-band PEQ)
  • Source: Volumio (for music) + TV (routed through the DAC)
  • Room: Recently moved to a new house with a smaller living room. Speaker placement is pretty fixed due to space constraints.
The Goal:I previously used Volumio for DSP, but I’m switching to the Topping D50 III's built-in PEQ so room correction applies to both music and TV audio. I may still use Volumio for music specific fine tuning.
What I'm Looking to Improve:I mostly listen to Psytrance and electronic music, and I've noticed two main issues in the new space:
  1. Low volumes: Needs a bit more bass punch/body.
  2. High volumes: The treble/highs get a bit harsh and need to be tamed.
Since I’ve just moved, buying new gear is strictly off the table (My girlfriend would kill me :p ).
How would you recommend setting up the 10-band PEQ on the Topping to address this? And how to use in addition with the volumio FIR filters?
Thanks in advance!
Here's the (IMO) best way to use Parametric EQ for room correction:
But to fix this:
..PEQ is useless. You'll need to look for a product with Dynamic EQ/Equal Loudness Comprensation.
For example, the RME ADI-2 DAC and ADI-2 Pro series can do this.
