- Thread Starter
- #41
I think @JohnPM the author of REW (awesome software and thank you for the latest fix!) maybe be able to answer the question about measuring both speakers at the same time...
On that topic, let's imagine a little experiment.. Let's assume you are measuring a system consisting of 2 subwoofers and one of them has inverted polarity. If you measure them separately each of them will produce a nice flat curve, but when you start to listen to them they will sound messy. If you measure response while both are playing it will be clearly shown that they combined resposne is not flat. So, which measurement better reflects the real situation?
Edit: PS. I use the default values in REW (500ms right window), sweep mode from 10 Hz to 24 kHz and 1/12 oct smoothing. I also use Acourate's microphone alignment tool for final mic positioning. I use a multi-client ASIO driver with the Lynx Hilo, so I can run REW and loopback the sweep signal into JRiver's ASIO line input and passes it through the convolution engine with the correction filters, digital XO, etc., in the circuit...
So your graph is showing a single sweep from left and right speaker?
