AmeliaBuns
- Joined
- Oct 3, 2024
- Messages
- 26
- Likes
- 4
Hi, I just got my UMIK-1 and I also did notice that it's extremely quiet when using it as a normal mic, I can only hear a noise when I'm very loud (yes it's set to 100%) but regardless I set to measure my speakers and I got this result after averaging some slight variations.
After seeing the huge gains of the suggested EQ I expected a large difference but was sad that the main difference is a tiny bit of extra bass (in an annoying way) and some changed in lower ends. I can't tell too much of a difference however.
I use a Kanto Ora + Kanto SUB8 under my desk with the kantos clamped to the back of my desk with DIY 3D printed mounts on a brass tube (empty inside, should probably buy some sand sometimes to fill them with it). I mainly listen to instrumental music which had almost no differences. I also listen to metal sometimes (not much these days) and I noticed light differences there but it wasn't a ton of differences.
now I wish I saved the money I spent for future IN-5/IN-8 (probably in-5 as I don't listen to music loudly at all) or more important things.
Any thoughts? What can I improve?
