marked sound
- Joined
- Nov 18, 2024
- Messages
- 91
- Likes
- 18
- Thread Starter
- #81
So if I am to understand correctly, the chain goes like this...To break it down very simply, it doesn't matter which amplifier you use, provided the power is sufficient even with DSP.
A test file is played, which is recorded at the end, i.e. after the amplifier and loudspeaker. This recording is compared with the original, evaluated and a filter/mask is designed that ensures that the test file and playback no longer differ (ideally).
Of course, this only works within a certain framework that the DSP can map and within the technical specifications of the amplifier, loudspeaker, etc.
Purely fictitious as an example!!! if a device can technically only play down to 30 Hz and up to a maximum of 17 kHz, then these technical limits cannot be shifted with a DSP.
#1. Source (Streamer/DAC, cd player etc),
#2. Room correction device with mic.
#3. Amplifier.
#4. Speakers.
Then if I am to further understand correctly, if I do use a PC with room correction software, or use come other external device that does room correction (miniDSP, McIntosh MEN220, etc), what happens is this...
#1. The room correction device has the proper measurements of what is ideal stored in its memory.
#2. A tone is played by the room correction device through the amplifier and speakers.
#3. That tone is then picked up by the microphone, that is hooked up to the room correction device.
#4. The room correction device then compares the measurements it received to the ideal measurements.
#5. The room correction device adjusts what info is being fed to the amp accordingly, so that the sound being outputted through the speakers matches ideal measurements.
Do I get the gist of what is going on?
Thanks
