I'm a bit puzzeld about my room correction measurments and the out come The picture below shows on the left side my measurement with resonance (gray line arc) and the predominantly straight-oriented line calculated by Mathaudio Room EQ. The right side is the original measurement of IMF measured over 35 years ago from my Compact II probably done in a lab environment a dead room or something. As you can see the Mathaudio straight line is quite similar to the IMF measurement, even the -15db mark is almost the same. So I would say I have done a good measurement if you compare both well with my untrained eye. What I find strange is that with the IMF measurement from -15db upwards the next level is -20db and with Mathaudio -10db. The question is to what extent can the two measurements be compared with each other, so the scales are not correct, but the frequency characteristics (what a word I had to google that one) are quite similar.
Can tell you the difference with or without roomcorrection in my partly threated room is huge. For instance i'm not using both subwoofers any more. After roomcorrection they where obsolete.
