Room correction and good sound like a wiim amp ultra but (more) inputs like a eversolo play
I own a wiim amp pro
Not enough difference in sound quality
A conundrum...
One could expand the inputs using a WiiM Ultra or another WiiM streamer as a source for the WiiM Amp Pro - but I do not believe it gets you to the inputs desired - and I am not sure what, if any usability problems would arise.
2 digital inputs - ARC and Toslink. You should be able to use the Sonos Toslink to HDMI adapter to use it as a second Toslink input, but I haven't tried it yet. USB is currently output only - they could add USB input capability (as in supporting input from an audio interface) in a firmware update but so far as I know it's not on the roadmap. Direct USB input from a computer would need a hardware change, or something like a USB to Toslink cable.
2 analog in 3 digital in, mabye one of each usb,optical and coaxial + 1 analog and 2 digital out (as there is now on a wiim ultra) + bluetooth
They just have to make usb both, either in or out, you deside in the wiim home app app
pc usb, cd optical, phono in turntable and the last phono which is called in for my tape deck + bluetooth for my phone
A conundrum...
A conundrum...
no no that won't give me better sound
Have inputs so i can use all of my source just not so each source can be adjusted individual,independent of each other + what ever sound quality a wiim amp pro has
It's also to get better sound when wanting a different amp, only option for one unit is a yamaha receiver if price is between a wiim ultra amp and double the price or up to 1300-1400 euros, most higher tier option are alot more than 1000 euros
improve a wiim amp ultra + eversolo (better amp, aut room correction) and raise the price by no more than 100 euros
I have sort of asked for a list with all in one amps with room correction but i still wanna know
An amp with aut room correction and good sound like a wiim amp ultra but (more) inputs like a eversolo play
Eversolo play has the inputs i need but the room correction and amp is better on a wiim amp ultra
What options do i have ?
Im going for something under 1000 euros
The Yamaha R-N800A may be an option. It uses Yamaha's version of room correction, YPAO, and has a lot of inputs. You will need to check prices in your region, but here in the U.S. Best Buy has it for $880.
I have wrote i don't want a yamaha receiver
It doesn't have any eq or peq i can use after room correction, it doesn't have any target curve when doing room correction, no option to measure the frequency responce before and after room correction, it's big
It does not have any eq or peq i can use after room correction, it doesn't have any target curve when doing room correction, no option top measure the frequency responce before and after room correction, it's big
I hope you realize that by not stating what you need clearly in your OP, you guarantee that people will have no idea what you are looking for and will suggest things you don't need or want.
More inputs,aut room correction,better sound around 50 watt in 8 ohm or 100 watt in 4 ohm under 1000 euros, not to big
Again eversolo play isn't better than wim amp ultra except for the screen and wiim doesn't make anything better than the wiim amp ultra
An amp or mabye combination that sounds better than a wiim amp ultra + more inputs MAX is 1000 euros which is just around 40% more than a wiim amp ultra
You keep saying "better sound". That's going to depend on your speakers, tone controls/EQ/Room correction, and room acoustics.
Otherwise, "an amplifier is just an amplifier" with no particular sound unless it's got excessive noise (or some other defect). And of course you need enough power to go as loud as you want with your particular speakers in your room.
Generally, a receiver or AVR gives you the most for your money but I'm not sure if you can get everything you want within your budget. :(
Yes also better sound, if not i wouldn't wanna upgrade
If i have a cambridge audio axa25 im pretty shure i would get better sound if i found a cxa 61 or audioloab 6000a mkII
It cost 1445 euros in denmark
2 analog and 2 digital
It is possible to change source if theres only one analog in (i don't use my tape deck that much but want to have the option if i need it)
If an amp has preout main in i think gain has to be universal for each source but room correction and eq,peg will work (what else the streamer has depends on what i can find)
I just don't know why there isn't alternative to that yamaha r-n800 amp for the same price or 800-900 euros
If you want the flexibility of more inputs and cheap then why not just stick a pre-amp with the connectivity you need in front of the Wiim?
If you want instead an all in one unit you'll have to specify exactly what your requirement is or we're all wasting our time.
Thats not a problem, how ever if i want to get a new amp i would like all of the input i need 2-3 analog + 2 digital and bluetooth
#30
More inputs,aut room correction,better sound, around 50 watt in 8 ohm or 100 watt in 4 ohm, under 1000 euros, not to big
