Room correction and good sound like a wiim amp ultra but (more) inputs like a eversolo play
gasolin75
Denmark
I have sort of asked for a list with all in one amps with room correction but i still wanna know
An amp with aut room correction and good sound like a wiim amp ultra but (more) inputs like a eversolo play
Eversolo play has the inputs i need but the room correction and amp is better on a wiim amp ultra
What options do i have ?
Im going for something under 1000 euros
What inputs do you need? Eversolo adds coax and phono ins. The phono ins are rare in these devices.
Have you looked at the combo of WIIM Ultra plus Vibe Amp?
An AVR will sort you out nicely
like 3 analog and 2 digital (eversolo has what i need i just wish usb was usb in)
I have all analog but 2 of them are also digital (bluetooth is pretty much standard on 99% of all modern i have room correction amps)
Im looking for what options i have, if i can see if theres any good deals and reviews
Having all inputs i need on the main amp makes it possible to use all of the feature instead of one gain adjustment for all sources and what ever special feature the amp has that can be changed for each source
You can't use all of the features since the sources connected to the amp can't be adjusted in the same way as sources connected to the streamer
That's like having a subwoofer and only be able to use it when you use your pc (you wanna use it all the time)
No thanks, to big, to much money spend on hdmi in,all of the outputs for external amps, thx software that might cost extra, much more inputs than i need, 7 or more channel, instead of the money being used for 2 channels, it has to be used for minimum 7 channels
Don't mind full sized amps but not as big as av receivers usually are
Problems is that the eversolo might have the inputs i need but better room correction and amp on the wiim ultra
Im raising the budget above an eversolo play to enhance my chance of finding something
A Technics SU-GX70 has just about what i need but that is 1500 ish euros (i don't like the yamaha network receivers that much)
Around 40-50 watt in 8 ohm or around 100 watt in 4 ohm
I can assure you i won't buy one
It doesn't have all the inputs i want and you can't buy one i denmark, if you could it would be around 1300 euros
Okay but there was no specific list of inputs in the OP. How would anyone outside of Denmark know what is available there? Good luck.
eversolo play has 2 analog in and 2 digital +bluetooth + the extras that is a nice bonus
It might be surprising, but even for 2.0, prices of AVR are competitive. Probably Pionieer LX305 or Onkyo NR7100 are within your budget, both include Dirac Live. And HDMI is a digital audio input too, quite useful.
The real downside is, that you need a monitor for setup.
Dirac Live nooo that is sooo expensive if it don't come with the full version
I have it all, source selector makes it harder to use different settings for each source
Of course depending on what settings there is
Does it *have* to be one box? WiiM Ultra (the streamer) seems to have your input requirements and there are plenty of small power amps that you can hook it up to. That's where I would go.
Lyndorf TDAI-1120 fits, but blows your budget badly.
wiim ultra don't have the required inputs, it only has 2 analog in and 1 digital + bluetooth, usb as fare as i know is only usb out on a wiim unit
lets say eversolo play is 5500 of my currency, a bigger more power full amp (more sound quality than more power) unless a yamaha r-n800 is something i want, is double the price of a everesolo play nothing inbetween
also 700-800 for a streamer with all input and room correction is also a little extreme + what ever a good power amp costs
2 digital inputs - ARC and Toslink. You should be able to use the Sonos Toslink to HDMI adapter to use it as a second Toslink input, but I haven't tried it yet. USB is currently output only - they could add USB input capability (as in supporting input from an audio interface) in a firmware update but so far as I know it's not on the roadmap. Direct USB input from a computer would need a hardware change, or something like a USB to Toslink cable.
