Room correction advice: Wiim Ultra to RME Adi-2 Pro FS R
Graph is clearly dominant with gains enabled
I honestly can't tell.
(Which graph is which? What dB range is shown? What smoothing was applied? Why do the screenshots show different frequency ranges?)
REW has a Screenshot button in the top left corner.
With Legend turned on, the resulting graph will answer all of these questions.
Should I apply any smoothing or REW can calculate precise Q on raw measurments?
MMM measurements with sufficiently high number of averages can be used without applying additional smoothing.
That's what you see here:
(Also note how the graph has standard 50dB amplitude range, sensible 20Hz to 20kHz frequency range, and shows the resolution/smoothing and name of each measurement at the bottom :) )
Yeah sorry attached plots were messy, both Var smoothed, but different average SPL, range of correction <280hz, single measure at listening point L+R.
MMM was used to measure each channel and generate EQ profile, though
