I'm sure barely relevant
and only intended for music recordings where the bottom end has been pillaged
AudioControl has a unit called Epicenter, designed for automotive use
that uses DSP to identify remnant upper harmonics from that artificially removed LF content
and "reconstructs / restores" it, maybe just one octave lower, or maybe more ?
You must feed FR signal for it to work, not pre- filtered LP material.
Its wired remote has two level controls, overall Volume - which acts as a Sub volume depending one how you deploy the downstream output
the other varying the "intensity of the restoration" process.
The Pro version lets you set a bass boost PEQ, center frequency and width.
I plan to test it using REW + ears, between Wiim output and SYN input, on content that seems bass deficient.
