watchnerd
I would love to see ASR do an assessment of tube rolling.
There is powersupply noise difference here. I'm not sure it's the difference between channels or the opamps.I guess these are the opamps from the voltage-amplification gain and the max. gain would probably be somewhere around 5X or so, right?
AFAIK, the opamps from I/V stage are more prone to sound change "effects" and artefacts, but also the ones from low-pass filter too, so too bad you can't test these two stages. Hope f=in the near future you'll be able to test this in another DAC.
I guess that if the measurements are about the same with both opamps, then the PCB is well-done and the PSU is indeed low-noise; perhaps bypass caps are well-placed and of enough capacitance. I'd love to see if pre & post ringing occurs with 20KHz squares when switching from Sparkos to TI.
BTW, is it me or the graph from this balanced measurement looks much better than the one from the initial review of H20 (THD+N: 116dB vs. 90dB)?
You hear pop when inserting your headphone into the plug because of offset. How many opamps have offset under 0.1mv? Is it shown on most popular measurements?
I think amirm shouldn't indicate that opamps are all the same. But that's what most people would think after reading these.
Yes.Good point with the pop thing when inserting the cans, but also worth adding the same pop noise when switching the gain adjust switch. I usually get that pop when I switch the gain button if the opamps installed in voltage amplification gain are having too much DC on the outputs (>10mV). Also, if DC-servo exists on the circuit and the output DC is too high to handle (or the DC servo opamps have been "upgraded" with an incompatible one).
There's a general opinion among audiophiles that swapping opamps will increase the performance of a DAC or amplifier. The measurements done by Amir are only proving that this is wrong and that we need to measure the performance after rolling opamps and then get the final conclusion. In the case of H20 makes no much sense to swap opamps from the voltage-gain stage, which is a very good thing actually.
Wrap the fuses with aluminum foil ... that ensures it won't blow and keeps your $ 150.- fuses safe.
Also just because sparkos is expensive, doesn't mean that "best opamps" has to be expensive. On the other hand, 49720 is already a pretty expensive opamp. opa1612 more so, opa2211 even more so.
I did one test on that: https://www.audiosciencereview.com/...be-rolling-of-schiit-saga-pre-amplifier.6522/I would love to see ASR do an assessment of tube rolling.
Even by the special standard of audiophile idiocy the idea of spending $$$s on audiophile fuses is particularly dumb.
Brilliant turn of phrase. ROFL.Even by the special standard of audiophile idiocy...
........ Shall I.............. No I'm going to decline this one....
Former was "unbalanced" output. The latter, balanced. As I noted, the unbalanced output is poor in this system. So for rolling op-amps, I resorted to dashboard view in balanced mode so we had maximum amount of room to see any improvement/degradation.Hello! Please explain. In the previous test we had SINAD 90dB. In this test 116dB. What is the difference?
