Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,636
So we have Amir's measurements. I've done my own measurements. What would change in the transfer function to give bass 3 times the slam? What change brings the mids alive?my babyface pro is connected to a singxer sa-1 then to focal speakers alpha 80.
when i put the 12v power adaptor (which i took from my little vaccuum machine} it took around 10-20 seconds to make a difference,
it upgraded gradually in 20 seconds time. the bass has 3 times the slam, the sound stage opened dramaticaly. the mids are alive,
it has to not be me the only one that is happening, i just informed my experience since i see people want to upgrade their babyface,
now i understand that the voltage is playing the biggest role in dacs
I don't know if I would bother, but if I did, you want to send me two or three tracks where this is totally obvious, and I'll do two versions of them. One on USB power, and one on external power, and then you tell me which is which when I send the files back to you?
OTOH, you have one of the machines, you could do some loopback measurements and see if anything changes. Any reason you couldn't do that? If the sound change is that dramatic there must be changes in the measured performance.
Do you get the same change if you connect the monitor outs of the Babyface directly to your Focals?
