Hi,
It really depends on what you want. I tried the Wiim products and they are OK as long as you don't want to play your own music.
What I like about the RPi4 running Moode is it's inexpensive and does a fantastic job.
I run Moode with a 256GB SAMSUNG MUF-256AB/AM FIT. It holds a ton of music.
moodeaudio.org
Love the RPi4 8GB - $82 or 4GB for $65
Samsung Fit - $23
Amor case $14
WD Purple MicroSD 64GB $14
Power Supply $10
$143 gets you a fantastic streamer that can be setup to automatically start playing your music once it boots or use the IP address on a computer/tablet/phone to control playback. If you want to use a streaming service then use your favorite player software with UPnP capability. There's nothing as flexible as the RPi4 running Moode and it does it while only using 6W even with the Samsung Fit drive attached. I plug the RPi4 USB port into the RME ADI-2 USB input and it's a wonderful match.
Whether I want to play music from the USB drive or stream from Audirvana using Qobuz via UPnP it does it all. What's cool is when RPi4 is connected directly to ADI-2 DAC FS and playing music from the Samsung Fit it supports playback up to 352.8kHz in my tests. You won't find that resolution available with other streamers. The max is usually 192kHz.
There's no need to pay more than $150 for a quality streamer.
You can customize your case, storage size, SD Card, power supply and the services supported. Turn on what you want and leave the rest off. It's a sweet package that lets you customize it to fit your every need.
