RME ADI 2 Series successor - the Pro EX
No more bands for EQ is disappointing
what do you mean??
From the available info on the website:
RME have incorporated many unique features, not found on any comparable devices, like 5-band parametric EQs for fully individual phones compensation, adjustable Bass/Treble controls with quick access, a binaural crossfeed function, adjustable loudness filter, selectable AD/DA filters, four discrete I/O reference levels, auto reference level setting, auto balanced phones mode, and many more.
Might be enough configuration options for me :)))
Why didn't they call it ADI-3? ;)
That's because the name is related to the amount of channels. I don't think they will change it anytime soon. :p
Do we know the internal chips yet? Curious if they're going with SOTA AKM or ESS chips.
what do you mean??
5-band PEQ has been a standard feature of all the legacy RME ADI-2 models.
Woulda coulda shoulda gone to a higher count with the new generation.
Or even go head to head with miniDSP, especially with greater "open ness" to non-proprietary standards.
Got it, thank you. Honestly, I think 5 bands might be enough for FR correction (without stripping the speakers/headphones of their character).
Do who know the internal chips yet? Curious if they're going with a SOTA AKM or ESS chips.
"It's likely based on the ADI-2/4 Pro SE with some modifications and upgrades. There’s a pretty high chance it uses an ESS chip."
feed the monitors AES-Signal and to connect the phono preamp directly. I would have also bought the predecessor- if available anywhere.
The 2/4 Pro you wouldn't even need phono preamp (I think that is gone now, but not sure, didn't they do it in digital domain anyway, not sure if it was MM only).
Don't know about the chips, sorry
5 is definitely much better than nothing but I'd have preferred to see 8 or 10 at least.
EQ might produce phase issues and make high end speakers sounds like a garbage if overdone.
This limitation might be due to DAC chip if it's hardware DAC chip EQ config (possibly phase and pre ring linear)
My only disappointment is that they switch to Type C (while keeping USB 2.0 protocol). My guess they go this route because of marketing bs + the supply chain / aftermarket cables availability (future proof)
Will have to deal with childish plug :( Otherwise, a nice incremental upgrade, will buy it
For the price of this that should never happen when much much cheaper units can deliver massive PEQ with no sound impact.
I read the USB C is some kind of EU requirement. I don't think they had a choice on that.
It's impossible to implement eq without artifacts both in digital and analog domains. I might be wrong it's even possible inside DAC. It's a hardcore engineering topic you can dive into by "linear phase eq / linear phase eq pre ringing" search keywords. My bet is that RME did the best job they can to implement the least destructive eq (making artifacts at least inaudible for human ear)
Not this one again…
USB-A and USB-B are only required to be designed to survive 1500 mating cycles. USB-C is required to survive 10,000, just because it’s bigger and chunkier doesn’t mean it’s more robust.
In portable device more cycles makes sense.
In a desktop product.... Not so much
I'm an idiot when it comes to audio science but I thought @amirm measured this and showed there was no impact to sound quality. Perhaps that doesn't capture what you are describing though. It's also entirely possible I completely misunderstood due to the first line of my post.
Huh)
Huh, if someone can't measure something it might not be because of it doesn't exists, but about the measurement method )) Although, eq artifacts are not a problem at all if you are not chasing perfect purity and use eq moderately
