Zensō
I’d suggest trying the EQ settings here:OK- decided to try and use the EQ on the RME and got out the manual. Im using Oratory1990 EQ for the Focal Clear.
Its a faff but getting there , but couple of questions on how to apply his particular filters:
1. Some of his gain settings are showing in tenths of a dB- eg 1.6 dB- I can only adjust gain by half dB intervals (Im not that bothered about it being that accurate, but I guess I'm doing something wrong if he suggests 1.6 and I can only dial in 1.5 dB
2. He sets up a peak filter with a Q of 7, I can only go up to Q5- so again, I must be doing something wrong.
Any ideas hive mind?
https://github.com/jaakkopasanen/AutoEq/tree/master/results/oratory1990/harman_over-ear_2018/Focal Clear
These are designed so that the first 5 settings can be used for the 5 slots on the RME. Just round the numbers up or down. Be sure to turn off the bass and treble controls if you go this route.
