I just used to check once a month. They put out updates very frequently.How do we get notices when new firmware is available?
I normally use an RPi4 with RoPieeeXL, but I've got a Touch with EDO in a cupboard so I dug it out. Seems to work ok, I tested some 24/192. (Couldn't get DSD working, normally this fails because I have to limit the max sample rate sent, which I didn't have time to mess about with. There are options to transcode anyway if required.)
Oh man...thank you!!!
Great reply to a first post. Again, thanks for the effort. I just ordered the unit. Looking forward to getting it in play, especially now that Deezer HiFi is finally enabled on the LMS platform.
The Pro ADC/DAC does balanced. A bit more expensive though.so @MC_RME when we'll all get an ADI-3 FS with balanced phone connector? im tired of moving back and forth the ADI-2 FS from the living room to bedroom to drive my main setup with Hypex NC400 and headphones collection
You won't regret it. I had a THX789 before the ADI-2 but don't miss it. (I don't have any balanced headphones.)
Really? What are you doing with your current DAC then?and i'll be never using the DA part
I have some balanced phones...well, can be balanced with the right cables. Using single ended connections currently. Was thinking I could use the RME as a DAC-only piece to the 789. Is that overkill or do you think there could be any benefits aside from the balanced outs on the 789? I know it's not true balanced out but I read it can dish a bit more power of needed.
I really wonder which Headphone needs more power than the RME provides? I know there are some HP out there with a bad efficiency and which can handle a lot of power too, but even in this case the RME should be able to drive them with a decent SPL. I would be concerned about hearing loss even with low efficiency headphones.I have some balanced phones...well, can be balanced with the right cables. Using single ended connections currently. Was thinking I could use the RME as a DAC-only piece to the 789. Is that overkill or do you think there could be any benefits aside from the balanced outs on the 789? I know it's not true balanced out but I read it can dish a bit more power of needed.
Both active at the same time.Would i be correct in assuming you can use both XLR and RCA outputs at the same time ? Or do you have to choose either XLR or RCA being active ?
Is it possible to say low pass the xlr out and high pass the rca outs?Yeap, you can, I use them both. XLR for the amp, RCA for the sub. Works perfectly.
ADI-2 PRO can do that with its two sets of channels with their own DSPs and DACs. For example:Is it possible to say low pass the xlr out and high pass the rca outs?
I've setup my ADI-2 Pro as a monitor controller. It can provide one-button selection of USB or DAC mode, selecting between two sets of speakers (one balanced, the other unbalanced), mono L+R, mono L-R, and use of headphone or speakers. These are functions that are commonly used when tracking, mixing, or mastering.
I would intend on using the xlr outs for the subs and the rca's to my amp, but i would like to trim the bass going to the rca out.
Sorry if this has been covered before, but i was unable to find the answers i need.
