ADI-2 DAC has a single stereo DSP and DAC. All analog outputs emit the same signal with the exception of analog gain.
ADI-2 Pro has an independent DSP/DAC for Phones Out 3/4, which can also drive unbalanced line inputs. A different EQ can be set up for it.
This is the correct answer regarding the PRO. The XLR and TRS* outputs on back are both considered output channels 1/2 — so while they each have their own amplifiers to their respective power levels, both are driven from the same DSP processing bank and receive the exact same signal.
The Phones Out 3/4 is slightly misnamed, since that port can be set to Line Out mode, giving it the same power level as the RCA 1/2 bank. So, you could run a TRS to dual-RCA cable and pull the subwoofer signal from the from port if you wanted to apply different EQ settings (e.g., Hi/Lo pass filters, PEQ for room EQ on the subwoofer, etc.). Also, on the PRO, you can route the signal out (via USB) to an off-board processor for multi-band EQ (full room EQ) and then return highly customized signals (via same USB) for channels 1/2 and 3/4 (and even for the optical channels 5/6 and 7/8).
RME (
@MC_RME): a feature request... please give us the ability to select whether the rear RCA ports are mapped to the 1/2 or the 3/4 output signal.
[*Corrected: these are not RCA on the PRO]
