Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,332
- Likes
- 11,219
Since it's been discontinued
When is ADI-3 coming out?
It is highly likely to be announced at NAMM this week, as others have said.Since it's been discontinued
Well.. didn't happenIt is highly likely to be announced at NAMM this week, as others have said.
I think you would have to buy one used and they ask prohibitive prices imo. What about that other topping. Dx5 IIAfter my topping d30 pro just died (probably, not sure yet) I was thinking about getting the ADI 2 dac. I've seen varying opinions, is the amp good enough to drive Arya Stealth? Currently I've been using the d30/a30 pro stack and yeah, it has lots of power, never went above Medium gain on them. I'd like to use the ADI 2 for both dac and amp and just give my a30 pro away but not sure if it has enough oomph.
Thank you
Don't mind the price, and i'd rather avoid more chifi for now. The d30 left a bitter taste in my mouthI think you would have to buy one used and they ask prohibitive prices imo. What about that other topping. Dx5 II
Check the A30 review. It has less power than the ADI 2 DAC Fs.Don't mind the price, and i'd rather avoid more chifi for now. The d30 left a bitter taste in my mouth
Have the a30 pro which I think has more power. Not that i'm using it fully, I never touch high gain on it with the aryas, usually im sitting at medium gain 50-70% volume.Check the A30 review. It has less power than the ADI 2 DAC Fs.
Then you have nothing to worry about with the ADI-2 DAC.Have the a30 pro which I think has more power. Not that i'm using it fully, I never touch high gain on it with the aryas, usually im sitting at medium gain 50-70% volume.
Just grabbed mine, new.Then you have nothing to worry about with the ADI-2 DAC.
Until we get the adi-3 in few months
I think mine does it automatically out of the box, didn't touch any settingsWith Auto Reference mode configured on my ADI-2 DAC FS usually volume setting is around 38 while playing music on my system.
To set up Auto Reference mode on RME ADI-2 FS devices, navigate to the I/O menu, select the output and set the Ref Level to Auto. This enables the device to automatically adjust hardware reference levels (+4 dBu, +13 dBu, etc.) based on the volume knob position. This setting is reported to maximize the signal-to-noise ratio.
The loudness function is not quite the same, and it is at or near the top of my favorite features with the RME devices.I've come to learn that the JDS element 4 has similar features that might be something worth looking into. It does have 12 band parametric eq, crossfeed, and loudness. I don't think you can do it all on the unit though it's done via software but it's persistent on the device itself. Although it might be worth it to get the RME ADI 2 used, I was able to snag one for about 575 USD and it was worth the money imo for the other features.
