Luvchampagne
but does this dynamically change the different PE bands as the volume changes? I believe that is what happens with the RME Loudness function. I miss it in my main system when I added my preamp. Keep it in my 2nd system.
You are right, there is a difference here. And of course the RME dynamic loudness can only work on the signal in the RME, not to volume changes later in the signal path.does this [parametric EQ] dynamically change the different PE bands as the volume changes? I believe that is what happens with the RME Loudness function.
I tried it with speakers, but it sounds too "fuzzy" to me, quite like an LP rip.This is a huge thread...
Is anyone here using the loudness function in conjunction with rear line outs/in a speaker chain? If so, how's your experience with that? I just ordered a used unit (looks like V2, since it has the 22-button remote but no letter on the serial code sticker), and am pondering the usage of the loudness function. I have a miniDSP Flex with digital outputs upstream applying DIRAC Live, which eats up a ton of gain (-10dB), so the higher reference level output options will allow me to simplify my chain (currently using a Topping L70 for gain staging and want to cut it out).
Perhaps I was not clear--I intend to remove the L70.The loudness function does not work unless you use the RME adi2 dac fs as a preamp.
Using the L70 will negate that.
Hi Chazz6. I have a couple of questions regarding this....I use the five-band parametric equalizer in the RME instead. Works fine. The RME could feed directly to my line amp, but I have a preamp in between them. So I can adjust the RME volume and the preamp volume to taste.
I can't answer number 2 since I disable the PEQ as well as tone controls, but for question #1 the RME has a very advanced volume control that combines stepped output voltage plus digital attenuation. In theory, it should be able to retain proper left/right challenge balance through the entire volume range, whereas the ALPS pots on the iFi might not maintain perfect balance in lower volume levels, but if you're not using lower volumes like that, then that's not a concern. Technically, the iFi is pure analog volume control, so you do completely avoid any potential digital loss of dynamic range which there might be on the RME's volume control (but that's really mitigated by the stepped voltage output).Hi Chazz6. I have a couple of questions regarding this....
1)If using the RME as a preamp to feed a dedicated powerful headphone amp such as the ifi iCAN Signature, is the volume knob on the RME active? If so, do you suggest using it *instead* of the one on the iCAN amp to adjust the volume? What are some disadvantages or benefits to controlling the volume from the dac side?
2)Do the bass and treble adjustments on the RME work when making adjustments to the PEQ? In other words, do they work in conjunction to each other, or do the bass and treble knobs become inactive once you start messing with the PEQ?
Not sure about 1) because I've never tried, but generally digital volume control will be more precise than analog (see the manual for description).Hi Chazz6. I have a couple of questions regarding this....
I can't answer number 2 since I disable the PEQ as well as tone controls, but for question #1 the RME has a very advanced volume control that combined stepped output voltage plus digital attenuation. In theory, it should be able to retain proper left/right challenge balance through the entire volume range, whereas the ALPS pots on the iFi might not maintain perfect balance in lower volume levels, but if you're not using lower volumes like that, then that's not a concern. Technically, the iFi is pure analog volume control, so you do completely avoid any potential digital loss of dynamic range which there might be on the RME's volume control (but that's really mitigated by the stepped voltage output).
Long story short, try both, and if you can hear a difference, go with what's better sounding, and if you can't hear any difference, go with whichever's more convenient to you.
2) You can use PEQ and B/T simultaneously, in the latest firmware after enabling it in the "Remote" software. Plus loudness, plus crossfeed if wanted.
BTW: I wouldn't do it while measuring for PEQ, obviously.
You have the option what is loaded with PEQ and what not, so you can use B/T as additional shelf filters.
I don't load them with PEQ, but use them with some subjectively suboptimally mixed music.
The "Remote" software has its own manual.
ADI-2-DAC FS - RME Audio Interfaces | Format Converters | Preamps | Network Audio & MADI Solutions
RME Audio Professional Live, Studio, Recording and Broadcast Solutions. Unrivalled Quality, Performance & Stability MADI Interfaces, Converters & Preamps.rme-audio.de
RME ADI-2 DAC (adaptive loudness and 4 crossfeed modes) - silly me, we are in its thread (i need coffee).Quick question. Are there any other DAC/HP amp products that support volume-adaptive loudness compensation? We see the Luxsin X9 has added the function recently. Any other product including portable devices?
But I have to askSome Chinese streamers and DAC/HPA but don't ask me which...
According to my search, the WiiM only has a PEQ setting for loudness compensation but it is not volume-adaptive. And the Topping DX5 II has not implemented anything yet. Did I missing anything?IIRC the Wiim family and the "neverending firmware drama" Topping DX5 II (but I might be wrong).
I have already participated in that thread with a different questionGood question... Maybe AI has the answer, but I would want to double check it (and have no access anyway).
There is a thread about loudness, maybe you can find answers there?
May I please ask if you use a different EQ between the balanced output and RCA output on the RME?I use the loudness function and I think it is one of the great functions of the ADI-2. I use the inbuilt filters to correct my main speakers amplified from the balanced output, and MSO/minDSP 4HD from the rca output for the subwoofers. On top of that there is also the tone control, of course.
RME's PEQ is equally as performant as EQApo's PEQ.Or does it simply NOT matter in the slightest?
