Count Arthur
- Joined
- Jan 10, 2020
- Messages
- 3,055
- Likes
- 7,807
its an old i5 , has intel 2500 graphics.
only supports directx11 and not fully, from what i just read
In which case, the card you linked to, should be fine.
read a few dogy comments regarding stability issues on this card so went for a slightly more expensive optionIn which case, the card you linked to, should be fine.
You seem to have missed the fine details. You have an AMD HD7800, and according to thismy gpu is 12 years old but does support the dx12 as per RME requirements.
you are absolutely correct.You seem to have missed the fine details. You have an AMD HD7800, and according to this
Feature levels in Direct3D - Wikipedia
en.wikipedia.org
the feature level up to AMD7900 is only 11_1.
Not much point in speculating about the cause until you do more controlled testing. What you hear seems very unlikely to be an issue with the DACs.Question: I've had both the DAC2 FS and the ADI2 Pro Black and they are by far the best measuring DACs I tried..
The problem for me is that I absolutely can't stand listening to music on them. There is something really wrong. I'm no audiophool and wanting to be objective I'd conclude that the way these DACs reproduce music is more "correct" and whatever is bothering me is actually in the recording and possibly obfuscated by less precise DACs.
I also owned a Fireface UC 15 years ago and I remember having similar thoughts about it.
My subjective and completely unverified experience with all RME devices is that:
I'm not sure how this can be but making the dubious assumption that I have a sensitive ear I'm thinking:
- They seem to have these sharp artificial high frequency range that makes the sound "thin"
- Lack of body in transients, flat and uninvolving, undynamic
So far the only thing that I've been able to verify is that at very high sample rates (352k+) there is ultrasonic noise in the ADC that gets up to -75db, but it's unclear if there would be any in the DAC output because I can only loopback into itself and have no other ADC. This has been confirmed as normal by RME and is quantization noise from the AKM chip, there is a mention in the manual too about the noise floor levels at higher sample rates. This is likely unrelated however..
- Something about the current output / analog output stage and how it drives the pre/amplifier?
- Ultrasonic noise not measured but interfering with speakers/headphones?
Other than that another observation that I'd make is that RMEs are the only DACs that in my experience have no variation in sound whatsoever provided that the same bits are sent to them. I have noticed in several other DACs that changes in buffers / output modes / USB streaming modes do change the sound subtly. Unfortunately I haven't found a way to measure that conclusively yet, but I think it's worth something that on these particular devices I can't observe the same thing, which I suppose is a testament to the quality of their drivers / implementation.
So just my thoughts here to see if anyone shares the same experience or part of it and has some ideas.
I would recommend a truly blinded, level-adjusted test between the RME ADI DACs and other DACs, with someone else doing the switching.Question: I've had both the DAC2 FS and the ADI2 Pro Black and they are by far the best measuring DACs I tried..
When your comments are *objective and verified* post your data and let us know....Question: I've had both the DAC2 FS and the ADI2 Pro Black and they are by far the best measuring DACs I tried..
I am doubtful that this will:When your comments are *objective and verified* post your data and let us know....
Sounds like it's time for new speakers. The RME is revealing their shortcomings.I am doubtful that this will:
A. Be believed.
B. Be well received.
Are there not RME folks that have recommended galvanic isolation....
- Rich
One might inquire, what speaker this person has, what speakers are recommended, and who is paying for them.Sounds like it's time for new speakers. The RME is revealing their shortcomings.
I only scanned through what you were saying, but did you say how you were listening and what the rest of the chain looks like? If you are listening with headphones or speakers and what are they. It has built in eq so why not use it to tame whatever is bothering you?Question: I've had both the DAC2 FS and the ADI2 Pro Black and they are by far the best measuring DACs I tried..
I would recommend you open the manual and thoroughly review the "Loudness" controls and install the ADI-2 app. With those controls I can make the ADI-2 sound anyway I want it. It's only limited to my imagination.
When I read this post it tells me the writer has only scratched the surface of what the hardware can do. The RME ADI-2 is not like a Topping DAC or others where you turn it on and get one sound no matter what you do. It can produce hundreds of different variations of tonal variances, bass boost and excitement in your music based on EQ and Loudness settings. If treble from your speakers is thin it can be adjusted to be crystal clear and if bass in the music is lacking, it can be adjusted to provide massive bass thump yet still remain totally in control. The results of the RME ADI-2 are solely based on the taste and skill of the user.
