- Joined
- Jul 24, 2018
- Messages
- 298
- Likes
- 373
I can only comment on the information I read from their material. If I am wrong show me how and I will apologise and thank for teaching me.@MC_RME often posts here, perhaps he would like to comment. I would imagine he put more than a little bit of thought into the design of this product. I see no reason not to trust him.
Maybe, when you find out, things will become clearer.I have no idea how they calculated the above figure
Very funny - not!Maybe, when you find out, things will become clearer.
This is not what' s written in the cited text. It's all about peak values.View attachment 249943
I can't believe that this is written by a company who is obviously competent in engineering. They assume the crest factor of music is 0db or just one!
I don't know, and neither do you. Until RME explain it's probably better to wait.Very funny - not!
If you disagree show me my error.
I show my calculations. On what grounds you refute them?I don't know, and neither do you. Until RME explain it's probably better to wait.
Please explain.This is not what' s written in the cited text. It's all about peak values.
This is difficult because the cited text is a good explanation. I have no clue how you come to your view that RME thinks that music has a crest factor of 0 dB.Please explain.
It is not difficult if you know, and no, their explanation is not good nor is correct. Here is what they say:This is difficult because the cited text is a good explanation. I have no clue how you come to your view that RME thinks that music has a crest factor of 0 dB.
…recordings with 6 dB of unused headroom are 6 dB quieter than other recordings that (typically) reach 0 dBFS. That may still be acceptable, but with 12 dB or more it just becomes annoying and unusable in practice.
The only word in the cited text hinting to loudness is "quiet". What the text says is that if a recording contains 6 dB of unused headroom (meaning the highest peak is at -6 dBFS) then it sounds quieter compared to a recording whose highest peak is at 0 dBFS. What it forgot to state is that they talk about recordings with similar crest factor. I assumed this to be the case. My BadThe loudness of a recording has nothing to do with its level reaching 0dBFS, nor any other dBFS value.
If a track measuring -6dBFS is 6dB louder than the one that measures 0dBFS the crest factor of the track should be 1 = 0dB. dBFS can only equal dBLUFS (the loudness) if the crest factor is 1.The only word in the cited text hinting to loudness is "quiet". What the text says is that if a recording contains 6 dB of unused headroom (meaning the highest peak is at -6 dBFS) then it sounds quieter compared to a recording whose highest peak is at 0 dBFS. What it forgot to state is that they talk about recordings with similar crest factor. I assumed this to be the case. My Bad.Yet I still don't know how you reach the understanding that RME thinks music has a crest factor of 0 dB.
From the user manual. They call it a buffer & ASP.I did not spot an analog preamp with adjustable gain in front of the ADC in the block diagram posted somewhere above).
The text says that the recording reaches 0 dBFS compared to one that reaches -6 dBFS (with 6dB unused headroom).They talk about the peak levels, not the loudness. At least this is my understanding in this context since headroom is the difference between 0 dBFS and the level of the highest peak.If a track measuring -6dBFS is 6dB louder than the one that measures 0dBFS the crest factor of the track should be 1 = 0dB. dBFS can only equal dBLUFS (the loudness) if the crest factor is 1.
The sentence "recordings with 6 dB of unused headroom are 6dB quieter than other recordings" is about loudness. What can the word "quieter" mean otherwise?The text says that the recording reaches 0 dBFS compared to one that reaches -6 dBFS (with 6dB unused headroom).They talk about the peak levels, not the loudness. At least this is my understanding in this context since headroom is the difference between 0 dBFS and the level of the highest peak.
Fine with me, let's agree to disagree.Anyway, I said what I had to say in public. RME is wrong and if they want to argue their case they can do that on this or other thread.
You are gentleman, sir. -- I hope the pronoun is correct, its not easy to guess the bear's cloths, not that it means anything these dayFine with me, let's agree to disagree.
You don't understand how the ADI 2/4 works. So how can you argue it doesn't achieve its claimed specs? Options are a) RME are correct b) someone who doesn't know how the 2/4 works is correct. Both are possible but one is more likely.I show my calculations. On what grounds you refute them?
