REW waterfall vs Amir's speaker measurement waterfall
Pdxwayne
I like how the bass sounds in my living room when playing Hans Zimmer music.
So I thought I would check the waterfall measurements in my room when playing right speaker with right sub (mic 9.5 ft away, 0 degree toe angle from speaker). Here is how it looks. It seems no obvious big problem for bass?
I than see Amir's waterfall that only uses 4 msec of decay time. For example:
I wonder how do I get similar look with REW for 4 ms? REW seems to default to 300ms and if I use 4 ms, I got no useful information. For example:
Any tips?
Thanks!
sailor2005
You won't. Because you are actually measuring your ROOM with REW. Amir measures the SPEAKER. The decay time you see in your measurements includes reflections in the room, Amir measures decay produced by the speaker itself, resonances in cabinet and drivers.
Pdxwayne
Pdxwayne
Also worth noting is that to examine the bass region, restrict the waterfall to 300 Hz.
Thanks!
I was under the impression that sometimes we want to know the balance of the decay for the whole range. For example, I see one site that sells absorption panels using full range measurements?
Pdxwayne
Pdxwayne
I see.....So REW is not the right tool. Thanks!
Trouble Maker
Columbus, Ohio, US
I took it as there are two different questions being asked. Not that your answer to your question was wrong. But I'm also learning so any experts please correct if needed.
Q1: What's the speaker behavior A1:Like this using anechoic measurements e.g. Klippel NFS
Q2: What's the behavior of the speaker in the room A1: Like this using in room measurements e.g. REW & Mic
2 different things.
I'm imagining that reverb/delay times in room are quite long compared to just the speaker. The sound has to bounce around until it looses enough energy to dissipate as it collides with and reflects off things around the room, combines in and out of phase with other like frequencies that are also moving around the room, escape via any openings, looses energy to moving/heating the air molecules (probably not a significant effect in practice but calculable in a sealed environment). Whereas in anechoic it should just be the initial incidence of sound since there should be no reflections.
Pdxwayne
Pdxwayne
If you had a mini amp and a laptop, you could measure outside via ground-plane.
Thank you and @Trouble Maker
I see that Amir's test is to measure speakers without the room. I can still use REW, but measurements should be made outside.
For me, since my room plays a big role in overall decays, using REW for in room waterfall measurements is the correct one to consider in my case.
napilopez
NYC
Any tips?
Thanks!
As others have mentioned, from that distance in room, you're not going to get results that match Amir's.
That said, and though I don't really like waterfall plots, you can actually get somewhat similar results with REW to Amir if you take quasi-anechoic measurements. Keep in mind it's not just the time range you need to adjust though; you need to adjust the rise time to be smaller too. I use 0.2ms.
For example, here's Amir's of the JBL HDI-1600:
Here's mine of the same speaker. Showing the settings in case anyone wants to try it out when making their own quasi anechoic measurements.
Not as accurate especially as this was a test measurement, but you see the same issue around the crossover, at least.
The "Window(ms)" setting will obviously depend on whatever window is effective for your own quasi-anechoic data. But to get the 'look' of Amir or stereophile's CSD plots, something roughly akin to these settings should work.
Edit: also note you'll have to fiddle around with the left scroll bar to find the right SPL cut-off.
Pdxwayne
Pdxwayne
Thanks for the advise about rise time!
tuga
Oxford, England
That tweeter resonance is way too close for comfort... Thanks for showing us the settings.
