- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,829
Great.I did not increase the buffer size since I'm no longer seeing the drop - a conundrum.
What do you mean by, "At these frequencies sound is not directional and angle does not matter?"Happy to see you make progress.
At these frequencies sound is not directional and angle does not matter. What matter is positioning in space and proximity to walls.
REW has a room simulator built in. It can give you hints what dip is caused by which position. However in the end there will always be a compromise. Again only sub(s) positioned strategically can give you a near perfect low frequency response.
Your question was why one speaker shows different low frequency response and assumed it was due to the angle. My answer is that it is not the angle as at low frequency you can angle the speaker anyway you want and it will (hardly) make a difference as the low frequency sound is radiating in all directions equally (to put it simply). Different for higher frequencies though. See the spinoramas of Amir’s measurements for the exact radiation pattern of your particular speaker.What do you mean by, "At these frequencies sound is not directional and angle does not matter?"
I will give the room simulator a try. I suppose I could do some monitor re-positioning, but I'm not sure what to try. I hope the REW simulation will provide a few suggestions.
I did generate EQ files from today's measurements. It does improve the sound.
What would I need if I were to buy a subwoofer to improve my low frequency response? I have REW and the ability to generate multi-channel FIR filtering, so hopefully I have the means for dsp. Right now my Adam T5V speakers are connected with balanced cables to a L50 amp and DO100 dac, which in turn are connected to my Mac computer via usb. Would I need a preamp, or an ASV? If so, what relatively low cost options are available to me? Could I vastly improve the low end with a $100 sub and a cheap preamp or ASV? I love the sound now, but if I could get a flat frequency response for little money, then nirvana! Besides, it’s a bit of a challenge.Happy to see you make progress.
For sub integration you need something which controls the signals going to sub and main speaker. Currently you are doing this via SW EQWhat would I need if I were to buy a subwoofer to improve my low frequency response? I have REW and the ability to generate multi-channel FIR filtering, so hopefully I have the means for dsp. Right now my Adam T5V speakers are connected with balanced cables to a L50 amp and DO100 dac, which in turn are connected to my Mac computer via usb. Would I need a preamp, or an ASV? If so, what relatively low cost options are available to me? Could I vastly improve the low end with a $100 sub and a cheap preamp or ASV? I love the sound now, but if I could get a flat frequency response for little money, then nirvana! Besides, it’s a bit of a challenge.
OK, but how do I connect the subwoofer (like this one), to my system? What's the interface?Or
d) You use the (studio) subwoofer internal LP/HP filters/crossover for "bass management". And of course your microphone for the integration measurements to find the optimal placement and settings (level, crossover, phase).
I'd rather not go the route of a miniDSP (or Dirac Live), mostly because I want to keep costs low, but also because I'd like to get it to work using REW (free) for measuring and Hang Loose Convoluter (HLC) for applying FIR filters to my system.For sub integration you need something which controls the signals going to sub and main speaker. Currently you are doing this via SW EQ
The following options come to mind
a) MiniDSP. Here you would set the EQ in the device and not via SW EQ. Not too expensive and small.
b) AVR. Overkill for your desktop application.
c) MultiChannel Audio Interface. Here you need an Audio Interface which can do multichannel and most importantly where you have drivers or software to send different signals from your SW EQ to. Honestly I don’t know if that exists. I have an audio interface (Focusrite 4i4) which can do multichannel and there are more, but I am not certain if there is an interface to a SW EQ.
What you already have for the full range monitors.OK, but how do I connect the subwoofer (like this one), to my system? What's the interface?
Absolutely possible with careful integration and then EQ. But a sub will be wife-compatible?Yes. That's a distinct possibility. However, I'm still wondering if I can smooth out the low frequencies with a sub.
My wife is accepting my Adam T5V monitors. Actually, she's said nothing about them, which qualifies as being acceptable. With my desk at an angle to the wall, I have space behind the desk (in the corner is my only viable location - which generally is the best location) to put a sub - so out of sight, out of mind.Absolutely possible with careful integration and then EQ. But a sub will be wife-compatible?
That’s good to know, and I’ll keep that in mind when I do some REW measurements today with the replacement dac. However, if that’s the situation, perhaps I need a different dac than the DO100. I want individual channel measurements. Is there any way to know if the SMSL DO100 has that auto-mute function other than via REW measurement testing?Regarding the 5 kHz drop-off, some DACs (with ESS chips?) have an auto-mute function that activates if there is no signal on the left channel for a few seconds, makes it difficult to use them for individual channel measurements.
I'm using REW for EQ measuring. When measuring the right speaker I got a steep drop at 5kHz. Another measurement it was at 10kHz. This was for R channel only. The L channel didn't have this issue. Yesterday I received a dac (SMSL DO100) replacement. I'll EQ measure my stereo monitors again today using REW - separate measurements for L/R channels. I'm hoping I don't have the steep drop issue with the new dac. If I do, then perhaps I have an auto-mute issue, not a R channel dac problem. I'll know later today.Play any test signal on the right channel only, if it stops after a few seconds that would look like the mute behaviour. You could just send the test signal to L+R all the time and unplug the connection to the speaker not being measured, though that seems a faff. Did you post about having another DAC earlier in the thread? Could use that or use the built-in audio of the Mac, don't need anything special for acoustic measurements.
I've had issues with my DO100. When making REW measurements for EQ I was getting sudden dropouts around 5kHz. So, I was able to replace the dac. Unfortunately, the replacement has the same issues.Play any test signal on the right channel only, if it stops after a few seconds that would look like the mute behaviour. You could just send the test signal to L+R all the time and unplug the connection to the speaker not being measured, though that seems a faff. Did you post about having another DAC earlier in the thread? Could use that or use the built-in audio of the Mac, don't need anything special for acoustic measurements.
