Revox B 226-S Review (CD Player)
NTTY
Reviewer
Switzerland
Hello everyone,
This is a review and detailed measurements of the Revox B 226-S CD stereo player and transport.
This player is a higher level clone of the Revox B 126, which I already reviewed. The main technical difference between the two is the presence of the Philips DAC TDA1541A in the "Crowned" version here (S1).
At the time there were a lot of folks claiming all sorts of extraordinary improvements related to the use of this selected DAC, and since it is implemented here in the same good quality environment, time has come to know the truth, at least on a measurements perspective.
Revox B 226-S - Presentation
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
This CD player was released in 1991 at nearly twice the price of the B 126, yet featuring the same internals with variable outputs on top. So we find the Philips Oversampling filter SAA7220P/B and the DAC TDA1541A-S1 (instead of the standard TDA1541A in the B 126).
So the main differences are on the outside. Other than the color, there also wooden side panels piano black painted and golden feet... Buttons are golden too on their top edge. The display is fluorescent (blue).
At the back, we get holes, this time, to access the variable outputs since it has the circuitry inside:
Inside, I let you compare with the B 126, for fun:
We have the TDA1541A-S1 with its surrounding decoupling caps, that are different from the B 126, and that could be due to the different production date of these two as I could not find a difference, or recommendation for it, in the service manual.
We see the circuitry for variable outputs, which was empty on the B 126.
The drive is extremely fast to skip one or multiple tracks, similar to the B 126. Scanning a track is little slower than others (again same).
EDIT (20/12/2024): When using the Revox, I noticed some slowness to read the TOC of my test CD and others, so I went for a little refresh:
The intention was not to improve the measurements, but it couldn't do harm and some caps looked tired.
That said, it gained 1dB in noise and distorsion, so I updated couple of measurements without further mention, as it's not of big significance. Other than that, I achieved my initial goal which was to make the drive faster at reading the TOC, and it’s too at skipping a track (I think, not really sure, it could be an impression).
Revox B 226-S - Measurements
From now on, I will be consistent with my measurements as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
The Revox B 226.S outputs 2.10Vrsm, and there was a slight channel imbalance of around 0.13dB, the B 126 did better (0.04dB only). The single-ended outputs are non-inverting.
Here you go with the 999.91Hz sine @0dBFS (without dither) and updated after servicing the unit:
I'll let you compare with the B 126, and this is very close.
THD at -103.7dB, instead of 102.5dB, so that's an equal wow! This is impressive result for the time, one that we don't always find in recent CD players... The two channels have near identical performances, similar to the B 126.
We continue at lower level, that is same 999.91Hz @-6dBFS (without dither):
Again, basically the same performances as the B 126.
Same relatively quiet power supply section too:
Not much leakage from the mains (50Hz in Switzerland).
The below is a new measurement with shaped dither added to the signal and compared to no dither, to see if the DAC has the necessary resolution to benefit from it:
And again, similar to the B 126, nothing to gain from shaping the noise unfortunately, at least at full scale, the conversion generates too much noise, I'd say.
That said, at very low level, noise shaping still helps to have a very decent linearity, here below a tone at -110dBFS which is correctly represented:
It again is the same thing you can see with the B 126 and its non-crowned DAC.
You might have noticed that the pitch error is a little higher with this one (1000.07Hz for 999.91Hz requested and the B 126 was at 1000.02Hz).
Anyways, what you see above means we are way below the strict resolution of the CD Audio. The software calculates a resolution that is near 18bits in this context. Thanks to noise shaping!
Bandwidth (now measured from a long term average of periodic white noise) is nearly flat:
You can see the ringing of the oversampling filter at the upper frequencies. And we also find our 0.13dB channel imbalance (vs 0.04dB with the B 126).
Let's continue with the oversampling filter behavior (from white noise) and together with dual tones 18kHz+20kHz (AES17):
Again, same as what we saw with the B 126 and that is logical because it's the same digital filter, so we find the same attenuation (-50dB minimum) out of band and the same ringing of the filter.
Multitone is also the same as the B 126:
It clears CD Audio data from unwanted distortion and noise.
This is the Jitter test:
On more time, it's nearly identical to that of the B 126, and that is normal for a clone CD Player.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-25X-30.2dB-24.2dB-27.9dB
Yamaha CD-1 (Non-Oversampling CD Player)-86.4dB-84.9dB-78.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Revox B 126-60.9dB-41.3dB-23.3dB
Revox B 226-S-61.1dB-41.3dB-23.3dB
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the Revox B 226.S mean the oversampling filter has roughly 1.5dB headroom, which is good because it will prevent intersample-overs and therefore clipping where it's most likely to happen. The Yamaha CD-1 shines here because it's old enough not to have an oversampling filter.
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -96.7dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -90.0dB
  • IMD DIN (250Hz & 8kHz 4:1) : -86.8dB
  • Dynamic Range : 97.2dB
  • Crosstalk: -116.6dB (1kHz), -99.9dB (10kHz)
  • Pitch Error : 20'000.00Hz (19'997Hz requested) ie -150ppm, this is worse than the B 126
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PL-20018.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Pioneer BDP-LX5818.5bits98.93%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
On this test, the Revox did better than the Sony CDP-3337ESD with two TDA1541A set to mono-staggered conversion. It still is short of 0.2bits to reach the threshold I've set for this test. The main reason is the elevated distortion at lower output level, as is with all Philips TDA DACs.
Last but not least, I like to have a look a the THD vs Frequency when using a -12dBFS signal. This has proven to me to be a key differentiator, especially when I'm reviewing an old CD Player using R2R conversion (case here). Here are the results of the Revox B 226-S (Left and Right analog Channels shown, with one channel from the Orpheus Zero for reference):
And of course, I need to complement this view with a direct comparison between the two bros: B 226-S and B 126:
And voilà, here we see the real difference. The S1 version gets the benefit of improved linearity which shows when the signal goes down. At 1kHz (see the plot), there's almost 2dB less distorsion with the crowned version at -12dBFS.
It's also the same story @-60dBFS. And that's it.
Revox B 226-S - Measurements (Optical Out)
I've seen several of you reviewing CD players using their digital outputs, in case the results could be improved with an external DAC.
First the digital output (coax only) is as what we expect it to be, perfect (999.91Hz @0dBFS without dither):
Similar to the B 126, it was difficult to get a stabilised reading from direct digital feed, and I had to reduce the FFT size to speed the calculation and be able to show an FFT without windowing errors. This is due to pitch error.
Conclusion
As with the B 126, I was positively surprised by this player, especially the first time I read the THD at full scale (wow effect). Of course, as an old R2R not benefitting from laser trimming, it has its limitations, especially at lower levels without dither. The trick of Philips to test low level linearity before stamping those chips below a certain threshold was a nice way to avoid going expensive laser trimming on the production line. In the end, they made it a marketing advantage and it worked. Well done.
Besides the pitch error, I don't see anything to be worried of. We do better today, but it was already crazy good at the time. Noise shaping technique of today saves this DAC at very low levels and since it delivers at high levels, and with a decent resistance to inter-samples over, well... quite modern after all, no?
Now we also get a tangible view at the potential advantages of the "S1" version of the TDA1541A. The improvements are as they were documented by Philips: minimal but tangible.
There’s a lot to like about this player.
I hope you enjoyed the review!
Cheers
PS: I add a link to the nice maintenance guide with many drawings that look to be made by hand.
Yeah, weird. There must have been a systemic error, like maybe they got a bunch of duff crystals or the values chosen for capacitive loading were incorrect for some reason.
I would recheck that. I don't see a noise floor down by more than a handful of dBs there. What ADC sample rate and FFT were you running again?
I picked up an old Phillips CDB560 CD player a few year ago , I believe 1985 vintage for about $8.00 US dollars'. It works great, but it was the only CD player that caused ear fatigue, for what ever reason, that I ever experienced . I used it for about two years as a transport. I think you just, myth busted, the Phillips TDA 1541 DAC chip as being anything more than just another DAC chip.
I will need to dig into that indeed.
I’ll check the files later but 256k is my standard FFT length for this measurement. I restricted the computing of ENOB to 6000Hz. It does not go down much, I agree. The same restriction to 6000Hz with rectangular dither would show 17bits I believe. I would need to run the test again to confirm, and I can if you’d like.
Well, they were not bad but indeed had nothing really special, even at the time. There was no magic.
I was very much interested by the measurable differences between the crown and non-crown versions. Now I know. In the bigger picture, it did not matter. I prefer seeing a good channel balance than 2dB less of harmonic distortion, for instance, not to mention the pitch error here. Nothing related to the DAC of course, but just saying that there are multiple elements in a CD player and many are equally important. Focusing on the “S1” version made no real sense.
I anyways think there’s as much in the oversampling filter as in the DAC, and only the latter gets a little improvement here.
I’ll soon review a Sony player with the same TDA but a different filter from Sony. And that will draw a different picture.
Reactions: tpd
Re: Your were right. This is below 999.91Hz @-80.77dBFS with rectangular and shaped dither. Span limited to 6kHz (input of the interface at 24bits/96kHz and 256k FFT). The difference is limited.
And to be complete, the same view but processing the WAV files directly (no player involved):
I still didn't interpret this picture. The low level square wave seems quite distorted instead. What means exactly? Non linearity of the DAC?
That signal in my understanding is to stress the spdif interface with precise symbols sequence that are not easy to manage by the pll clock reconstructor, isn't it?
Cheers,
Luca
I wouldn’t be able to tell you the exact source/cause. But it could be noise within the payer that introduces some clock deviation and therefore jitter components appearing in that test.
Jitter appears when data is transferred indeed, and there will be more on long distance transmission. But it could also be the case inside the player, as we see here. Jitter can also be introduced from many sources, including and not limited to oversampling, noise shaping, sample rate conversion, etc…
I sent this one player for a clock update, by the way. I’ll report on the potential improvements.
Stereophile was often using the 3DC measurement as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest sign magnitude digital signal:
Yes, but you are sampling at what frequency- 44.1?
You won't get anything clean or useful unless you sample at 192kHz or above. Get out that DSO...
Maybe I've figured it out, it's simply intermodulation distortion, each spectrum line is in between the original ones, they're multiple of the difference between the 11025 raw and the square wave ones.
Hi John,
I think I see what you mean but if I sample at higher rate, I get more noise in the view as I can’t filter below fs/2 when using the scope view of REW.
I liked this measurement of Stereophile but it’s true I don’t get more information with this view that I don’t have elsewhere. And since I never got a near perfect view, I suspect the noise of my interface to be too high.
Time has come for the DSO indeed.
Hi everyone,
Since the Revox became a little slow at reading the TOC of some CDs, I decided to service it. I updated the initial post with two pictures and couple of measurements. Not that it is of significance but I saw a 1dB improvement in THD and noise, so I updated.
The little improvement showed also with my preferred measurement of THD vs Frequency @-12dBFS (Left and Right channels compared with the Revox B 126):
I did not update the initial post with this view as I don't think a 1dB less of distortion is related to few caps change, so I add this one here for further reference, because I'm not done with the Philips TDA1541A family ;)
Anyways, it's now fast to read TOC, as I expected, and some other caps were in need of a refresh, so it's now good to go for 40 more years!
Всем привет!
Это обзор и подробные измерения стереопроигрывателя компактных дисков и транспорта Revox B 226-S.
Уважаемый @NTTY, можете ли вы рассказать что-нибудь о переменном выходе этого устройства? У меня такой же, и я иногда подключаю его напрямую к мощности усилителя, регулирую уровень звука с переменным выходным сигналом. Вы измерили этот результат? По вашему мнению, сильно ли ухудшается качество звука с переменным выходом? Вы используете этот revox как транспорт через цифровой выход? Спасибо.
