I'm sure some of you are aware of the following that has developed around the vintage Realistic 42-2101a and 42-2109, with the former made in Japan and the latter made in Korea.
I'm very fond of at least the 42-2109. I built my own turntable using a motor/platter from a Technics linear model, and I made my own DIY unipivot arm.
I then went on to try a multitude of phono preamps but ran into three main problem areas: (1) Hum. A lot of them just could not be arranged, at least in my system, so that hum was acceptably low. (2) RFI. Same as #1 above, I live nearby some radio station broadcast towers, and could easily hear radio stations on some models. This I could help with ferrite cores, but... (3) Sub/Infra (take your pick) -sonic energy causing woofer pumping. Many didn't have switches to cut this LF output, which is often baked right into a recordings.
I tried a bunch of models but none were acceptable in all three departments above, except a vintage 42-2109. While the 42-2101/09 don't have sub/infra-sonic filters, they do roll-off at 30-Hz, so that is that.
One aspect I've enjoyed about the 42-2109, is that it seems to make playback of mono vinyl a joy, even without having a mono switch/cable arrangement. Many of the other phono stages I've tried sounded very flat when playing mono recordings.
A few months ago, I started looking for a 42-2109 that wasn't scratched on the top (my original has some superficial scratches), and I've recently found one and swapped it into my system.
So I have this spare 42-2109 that I'd happily ship to someone for testing, so we can all see how good or bad it really is.
If there is any interest. If not, that is okay, too.
Maybe this one has been tested elsewhere, but I haven't been able to find anything.
