Briocat
- Joined
- Sep 23, 2025
- Messages
- 34
- Likes
- 6
On February 3, 2016, in the thread "Hot Take (or not), if you EQ your headphones to your ears, you can easily beat ANY unEQ'd headphone." I wrote: "I, too, had trouble trying to get the best EQ for my headphones. I finally solved everything with a simple and inexpensive solution: the FiiO JT7. All I had to do was eliminate the annoying peak around 6kHz and pair them with an underrated DAP like the Surfans F28, which has a rich bass sound without the need for EQ. The result: a delight, and I'm left wanting nothing more."
Yesterday I happened to listen to the song "That Ain't You" by George Terry with the JT7 and immediately after I wanted to compare the same song with the Sennheiser HD 560S. Aside from the greater openness in the high frequencies of the HD 560S, I "discovered" a cymbal sound that rhythmically accompanies the song that I had never heard with the JT7. This made me reconsider the qualities of these headphones, which initially struck me, among other things, for their faster impulse response, compared to the Sennheiser, and which I had immediately noticed upon first listening.
