- Thread Starter
- #161
Most likely it is from the change of DAC's bitrate. Similar pops and clicks due to bitrate changes have been reported in many DACs. It can be avoided by fixing the DAC's playback bitrate. For instance, on Windows I do not use any app's exclusive mode for content listening---I do use exclusive mode for measurement software like REW, though. For content listening I always include EQ APO in the signal chain, and for it to work, I do not use exclusive mode in an app like foobar2000. You may want to refer to:The pops I experience were far worse with firmware .2 , which it was initially loaded with when I recieved it. I'm using Windows 10, Intel based. I am using a powered USB hub but I have several DAC's and none of the others has the noise. Since the upgrade to firmware .5, the pops and clicks between songs etc are gone but I still get a small pop when the DAC goes to sleep and then wakes up again, probably to save power. I've just stopped Windows from powering down the USB controllers, so I'll see if it still pops occasionally. Update, I do still get a pop when I'm changing from my streaming service that is in exclusive mode to Youtube etc with the power managment adjusted. Perhaps the energy saving is internal to the Black Pearl and not just Windows powering it down.
A debate has been long raging in the audio community that Windows isn't fit for use in a high resolution audio system. Sceptics counterargued that bits are bits and Windows audio degradations are a figment of an over-active audiophile imagination.
I decided to investigate this as I kept hearing issues with Windows, even after following common practice to (controversially) supposedly make it clean. I found some surprises along the way.
Sorry for the long post but my motivation is to share how to get effectively perfect audio from Windows, to save folks money and headaches, and to help...
- DDF
- apo audio upsampling caudiolimier digital filter intersample over pc audio remote windows windows 10
- Forum: Home Music Servers, Computers and Streamers
