decebalus
ported the driver to android. it is "functionally complete"
View attachment 531031View attachment 531032
any android app for it ?
Thank you !![]()
GitHub - cheesyserg/BlackPearlControl-Android: Initial Commit
Initial Commit. Contribute to cheesyserg/BlackPearlControl-Android development by creating an account on GitHub.github.com
nice, ig i wont be making a web app anymore![]()
New Web Based control app for DACs with PEQ
It's an open source project that looks to be vibe coded using AI, but it works fine on a few my USB DACs like the Black Pearl and Fiio JA11. I find it easier to use than the original manufacturers apps plus there is no need for registration. If your DAC uses WalkPlay it will work with this app...www.audiosciencereview.com
When you use an external Amp, then no it won't clip:@jkim does the black pearl's output clip if i set the software volume and hardware volume to max?
thank you. i just need to confirm since the black pearl has some weird way of managing volume. when i was trying to find the volume registers for my driver software. i found that the software volume and hardware volume. somewhat has weird behavior.When you use an external Amp, then no it won't clip:
View attachment 544135 View attachment 544136
When you plug headphones directly into the black pear, then yes the black pearl can clip:
View attachment 544133 View attachment 544134
i had the jt7 (before i returned it due to a rattling sound on one earcup) pairing it with a 1Vrms dongle sounds fine and get it loud enough for me. but yeah if you wanna EQ them. you need a MUCH more powerful amp. even with a dac like the black pearl under balanced. yeah you have enough loudness and you can EQ for a certain point. but it is still not enough. if you need an extreme EQ. you really need a desktop AMP for that extra headroom.Hi team,
Long time lurker first time posting here. I recently got the Fiio JT7 which is my first over ear. Only non IEM I had before was the Moondrop Old Fashioned.
And as you expect non of my existing 1V dongles can drive the JT7 sufficiently. The only thing I have for now is my work MacBook Pro, which is locked down so no software EQ.
That’s the long winded background to me getting the Black Pearl. It’s still in transit from Aliexpress but now as I read more I realize I might not have enough headroom for EQ when using it with the JT7, since the Black Pearl might be current limited at lower impedance?
Any guidance? Did I make a stupid mistake for getting it? I have all these other 1V EQ dongles like the CB1200 and JM12 for my IEMs and consider them more than sufficient for those.
I apologize if this should be a separate post.
Thanks for the advice!i had the jt7 (before i returned it due to a rattling sound on one earcup) pairing it with a 1Vrms dongle sounds fine and get it loud enough for me. but yeah if you wanna EQ them. you need a MUCH more powerful amp. even with a dac like the black pearl under balanced. yeah you have enough loudness and you can EQ for a certain point. but it is still not enough. if you need an extreme EQ. you really need a desktop AMP for that extra headroom.
there is the fiio gigas 1 which has bonkers amount of power but it is still new and we dont know how well fiio designed the amp...
if you wanna cash out for a desktop amp ide suggest the topping L30ii. crazy amounts of power. you can pair it with a 2vrms dac to fully utilize it. but a 1vrms dac is fine.
edit: the black pearl starts distorting if i push it hard with bassy music
we already got crinacle's eq tool. so yeahDid a cleaner web EQ control: https://peq.flac.moe/
Repository: https://github.com/iljasrb/LightWebPEQ
Issue reports and PRs are welcome.
- AI tools were used to gather information about devices and protocols. Website implementation is also AI written. All of the functionality is manually reviewed and tested by me.
- Why!?: Because it saves me a lot of time: research, development and debugging. Still the core of website functionality is checked with tests and manually by me (only with TRN Black Peal tho). Codebase and styling is kept minimal and maintainable.
That's good, but it's always nice to have alternative software available.we already got crinacle's eq tool. so yeah
Hi, did you ever confirm if you had a fake or not?Savitech Kencent Audio USB\VID_262A&PID_0001\5000000001
Edit: some audible pops on the cmaj.steady and SotS test. great![]()
Sundara is 40ohm, around 104dB/1V sensitivity. If 110dB SPL as a maximum is ok for you (yes, it is VERY loud, at least for me), it will be driven properly from 3.5mm output. If you hear any distortion above 105dB SPL it will be probably sundara itself, Hifiman really does not care about distortion levels in its headphones above 105dB SPL.If I hook it to a computer, do you think a Black Pearl can properly drive a Sundara?
I confirm that too. On windows 11 for example 2Vrms output from 3.5mm is from 20/100 volume up to 100/100. If you want lower it in windows you need to go below 20/100.i just need to confirm since the black pearl has some weird way of managing volume. when i was trying to find the volume registers for my driver software. i found that the software volume and hardware volume. somewhat has weird behavior.
