Review of TRN Black Pearl: Portable USB DAC & Headphone Amp with 10-band PEQ
Rate this DAC & HP amp
  • Poor
    Votes: 5 3.5%
  • Not terrible
    Votes: 7 5.0%
  • Fine
    Votes: 40 28.4%
  • Great
    Votes: 89 63.1%
jkim
US
Important Update (8/16/25)
WalkPlay/TTGK is another company reacting to the issue of DRE-induced distortion associated with the CS431xx chips!
A new firmware release for the TRN Black Pearl changed a key parameter related to DRE operation. With this firmware installed, the Black Pearl does not exhibit audible distortion behavior caused by DRE while retaining reconstruction filter options. An analysis based on measurements was added to the bottom of this review.
Introduction
(Picture from TRN-Audio website)​
There are many portable DACs adopting the Cirrus Logic CS43131 chip, some of which have been reviewed here at ASR. Why do we want to see yet another review of the same kind? Here are some reasons:
  • This review will demonstrate, for the first time, that a CS431xx-based DAC can be completely free of the peculiar distortion associated with the chip, reported at Reference Audio Analyzer , by some audio enthusiasts, and in my previous review. Yes, completely free of the distortion, not even the problem shown in Part II of the review.
  • This review will assess, for the first time again, the noise performance of a CS431xx-based DAC with its DRE (dynamic range enhancement) function disabled.
  • The TRN Black Pearl is relatively inexpensive (< $50 at AliExpress) and supports onboard 10-band parametric equalization (PEQ).
Most CS431xx-based DACs measure very similarly to each other. Below are some comparable products and their features:
Tanchjim Space​
Fosi Audio DS2​
Moondrop Dawn Pro​
TRN Black Pearl​
USB BridgeComtrue CT7601Savitech SA9312LComtrue CT7601TTGK CB5100
NOS modeSupportedNot supportedSupported via button?Supported
Onboard PEQNot supportedNot supportedNot supportedSupported (10 bands)
Connection3.5mm, 4.4mm3.5mm, 4.4mm3.5mm, 4.4mm3.5mm, 4.4mm
Measured byASR, L7AudioASRASR (Unofficial)This review
Note that all these devices do not include an additional headphone drive stage in their design. So, they all rely on CS43131 for both D/A conversion and headphone amplification. They all adopt dual CS43131 to support balanced outputs.
The TRN Black Pearl is in fact a product designed by TTGK, an ODM (original device manufacturer) of portable DACs and dongles. It is actually the TTGK TT39518F01-Pro module housed in a black case and with CS43131 substituted for CS43198:
One thing I could not quickly figure out about this device is that it is turned on only if one of its output jacks, either 3.5mm or 4.4mm, is occupied by a headphone plug. Otherwise, it is not even recognized by a host device.
Why Disabling DRE Matters​
The technique of DRE increases a DAC's low-level performance and achieves a wider measured dynamic range (DR) by adjusting the chip's gain structure, depending on the signal strength, to find a good trade-off between digital and analog gain settings. DRE is not a new technology but has also been employed by other DAC chip manufacturers such as ESS and AKM. Setting aside the debatable point on whether the DR of a DRE-enabled device, measured by the AES17 standard procedure, is faithful to a theoretical definition of a dynamic range, criticism against these Cirrus Logic chips has been on the fact that the use of DRE is not officially documented by Cirrus Logic anywhere.
More importantly, DRE has been suspected to cause the anomalous distortion behavior observed from the CS431xx-based DACs. How would DRE cause this distortion? The idea of DRE is simple: whenever there is headroom in the digital input signal---say the signal's peak in a certain time window is 20 dB below full scale (dBFS)---, fill it with digital gain and decrease analog gain to achieve lower noise and hence increase the DR. However, unlike a similar technique, such as HDCD (High Definition Compatible Digital) that increases DR by applying DR compression as an offline preparation process (i.e., encoding) and reversing the process during playback (i.e., decoding), DRE operates entirely in real time. The problem is that audio signals are unpredictable when processed online. What if the headroom is abruptly decreased right after such an adjustment is made? Or what if the headroom is overestimated when the adjustment is made? For various reasons, distortion due to inadequate headroom can occur. Right, this distortion is nothing but a digital artifact.
So, DRE, by design, cannot work 100% of the time---i.e., it is destined to cause distortion even if a small % of the time---unless some pre-processing is done before input is converted. But such processing in a tiny DAC chip is unrealistic. For this fundamental reason ESS must have chosen to disable DRE by default in some of their DAC chips supporting DRE, like the ES9219 and ES9080. But DRE may still be used in such a way that it would incur distortion, say, only 0.000001% of the time. This would be accomplished by carefully choosing associated parameters. I believe Cirrus Logic engineers must have been too greedy in setting the default parameter set. For example, the maximum DRE gain in CS431xx is 24 dB, which is absolutely unnecessary. A max DRE gain of 12 dB should've been sufficient. And DRE does not need to start its action at -12 dBFS as in CS431xx. It is too high (again unnecessary). A -20 dB to -30 dB threshold should've been safe. This way there would be adequate headroom so distortion would have been much less frequent and less severe.
Thanks to an ASR member's report, it has been found that DRE is disabled when a DAC is set to the NOS (non-oversampling) mode, if a device supports such an option like the Black Pearl:
DAC parameters and onboard PEQ filters of the TRN Black Pearl can be set from either its Walk Play web app or android app.
Although the absence of distortion was confirmed and reported in a post, I deemed that a full set of measurements and analyses would deserve a dedicated review.
Implication of Using NOS (non-oversampling) Mode​
Before presenting test results, there is one thing that needs to be made clear. Most modern DACs rely heavily on oversampling (same thing as 'upsampling' in this context) along with an interpolation algorithm to implement a reconstruction filter that removes quantization artifacts. That is, if digital audio content, created at a 44.1 kHz sample rate, is transmitted to a DAC, it is resampled within the DAC and interpolated by its built-in algorithm. When a DAC is set to 'NOS', the signal is supposed to be converted to analog audio without this reconstruction filtering. The consequence is broken soundwaves, shown in measurements as an early high-frequency roll-off and severe ultrasonic distortion. For this reason, when the NOS mode is used, the input signal should be oversampled by the host system. This is a price to pay for disabling DRE in the Black Pearl, or a similar CS431xx-based device supporting the NOS mode. Note that it should be possible to disable only DRE while retaining standard filters in a firmware design---I hear a rumor that a manufacturer is in the process of modifying firmware with this option. Fortunately, these days processing power is cheap. Computers and even mobile devices can handle this load without using too much CPU power. In measurements shown below, unless noted otherwise, the Black Pearl was tested in its NOS mode and with input signals resampled at a 192 kHz or 384 kHz sample rate, so not relying on the DAC's oversampling.
Measurement Setup​
Performance Not Affected by DRE​
We first look at a set of measurements that do not depend on DRE. All results shown in this section were obtained in the NOS mode in which DRE was disabled.
The full-scale SINAD of the DAC's balanced output under no load (20 kOhm) is excellent:
Note that this is essentially the same performance as other comparable devices based on the same chip, measured by others: Tanchjim Space, Fosi Audio DS2, and Moondrop Dawn Pro. This result would be placed at the top of Amir's portable DAC SINAD chart:
Its unbalanced outputs' SINAD results are just as expected (i.e., about 3 dB lower than balanced outs):
Not surprisingly, this DAC is fine with the usual package of measurements using steady-state signals (i.e., full-scale multitone, jitter, SMPTE IMD vs. output, and THD+N vs frequency tests). Since these are not the focus of this review, these measurements are shown in thumbnails below:
TRN_BP_Bal_NOS_32MT_Full.pngTRN_BP_J-Test24.pngTRN_BP_NOS_SMPTE_IMD_v_Lvl.pngTRN_BP_NOS_THDN_v_Frq.png
The full-scale 32-tone test shows slight high-frequency distortions. In the jitter test, some periodic jitter (shown in spikes) and broadband random jitter (indicated by the slightly elevated noise floor) are observed. But none of these are of audibly concerning magnitude. The stepped SMPTE IMD versus output and THD+N versus frequency results are great.
An important aspect of any portable combo device is output power. The Black Pearl's headphone drive capability is decent:
Note. These THD+N measurements were made a while ago with a standard reconstruction filter; so, noise at low signal levels is lower than in NOS mode. Still, the device's maximum power is not affected by a filter choice.
This performance is as good as it gets for a CS431xx-based device with no additional op-amps, equaling the Fosi Audio DS2 and slightly more powerful than the Tanchjim Space.
Output impedance is very low:
Output​
Left Ch.​
Right Ch.​
3.5 mm​
0.23 Ohm​
0.22 Ohm​
4.4 mm​
0.12 Ohm​
0.12 Ohm​
Note. This was measured by a voltage drop at 100 Hz across loads. Typically the impedance of a device's balanced output is higher than that of its unbalanced counterpart. For the Black Pearl, that is not the case here. I suspect CS43131's impedance detection and some kind of voltage compensation is in play.
Noise Performance: DRE On vs. DRE Off​
One way to clearly see the underlying effect of DRE is to look at the DAC's noise shaping because the effect can be seen without being masked by the device's thermal noise limit. When a test tone is between 0 and -12 dBFS, there is no difference in noise performance whether DRE is enabled or disabled. Below is a comparison of the two cases when a -12 dB sine tone is fed:
Below -12 dBFS DRE starts its action, and when the signal reaches -36 dBFS, noise reduction by DRE is in its maximal state:
Stepped sine tone tests using BW of 20 Hz - 90 kHz show this transition clearly:
The full DRE gain implemented in CS431xx is 24 dB. However, the practical amount of noise reduction in human hearing range (20 Hz - 20 kHz) is substantially less because the noise level is masked by the device's analog, thermal limit (or the measurable limit).
See the same stepped sine tone tests with BW limited to 20 Hz - 20 kHz:
Note. To enhance the noise limit of these measurements, the E1DA Cosmos Scaler's autoranger was used.
The measurable noise reduction of DRE in the frequency range of 20 Hz to 20 kHz is about 12 dB. This is still a considerably large difference. To get a better idea of what kind of noise performance these results indicate, we may want to look at the performance of other devices, including some well-regarded ones:
Note. (1) The noise limit of these measurements was enhanced by using the Cosmos Scaler's +26.7 dB gain.
(2) There were negligible differences between L/R channels except for the Hi-Max CB1200AU (see a note under the DR table below).
(3) The RME ADI-2 DAC FS tested here is the version with ESS ES9028Q2M.
SNR at the output of 50 mV:
Device​
SNR @ 50 mVRMS​
TRN Black Pearl w/ DRE on (3.5mm out)​
96.5 dB​
RME ADI-2 DAC FS (IEM out)​
95.9 dB​
E1DA 9039S​
89.9 dB​
Qudelix 5K (3.5mm out)​
87.6 dB​
RME ADI-2 DAC FS (Low Power)​
86.0 dB​
TRN Black Pearl w/ DRE off (3.5mm out)​
85.2 dB​
Hi-Max CB1200AU​
76.8 dB​
Though not as important, each device's dynamic range in its maximum output setting was also measured:
Device​
Dynamic Range​
Maximum Output​
TRN Black Pearl w/ DRE on (4.4mm out)​
132.7 dB​
4.06 VRMS​
E1DA 9039S​
127.8 dB​
3.49 VRMS​
Qudelix 5K (2.5mm out)​
123.3 dB​
4.10 VRMS​
TRN Black Pearl w/ DRE off (4.4mm out)​
120.5 dB​
4.06 VRMS​
Hi-Max CB1200AU​
103.3 dB​
1.01 VRMS​
Note. (1) Channel imbalance was negligible for the above SNR and DR measurements except for the Hi-Max CB1200AU for which average values are shown. The Hi-Max gave SNRs@50 mV of 75.9 dB (Ch. L) and 77.6 dB (Ch. R), and DRs of 102.5 dB (Ch. L) and 104.0 dB (Ch. R).
(2) I forgot to measure the RME's dynamic range in its max output setting.
Some notable points of these results:
  • Noise performance measured by this setup (E1DA Cosmos stack) is usually a few dBs better than measured by the APx555B.
  • Except for the Black Pearl, none of the devices under comparison employ DRE.
  • The two top rankers have obvious reasons for such outstanding performance, which makes comparing the other devices with them unfair:
    • TRN Black Pearl relies on DRE. In fact, an SNR of 96.5 dB @ 50 mV is unrealistically good, which would place it at the very top of Amir's 50 mV SNR chart.
    • RME's IEM output uses a buffer of negative gain (-10 dB) with its maximum output being only 0.55 Vrms.
  • It is impressive that the E1DA 9039S achieves an SNR of 89.9 dB at 50 mV while having a balanced gain stage providing its maximum output of 3.5 Vrms.
  • The Black Pearl's 85.2 dB SNR @ 50 mV with no DRE is still decent. We should not hear noticeable noise or hissing even from sensitive IEMs connected to the Black Pearl in NOS mode.
  • One may think the Hi-Max's 50 mV noise performance (76.8 dB) is horrible. Not at all. I think some of us are spoiled by today's DAC technology. Although this dongle's max output is only 1 Vrms, its noise level in itself is by no means poor. For instance, this SNR @ 50 mV is on par, if not slightly better, with the performance of the ODAC + O2 amp combo available a little over a decade ago. With this dongle, noise only in softly recorded content is borderline audible. In fact, without careful attention, I do not hear much difference in noise b/w this dongle and better measured devices.
Given that the CS43131 chip in the Black Pearl improves noise performance dramatically by using DRE, one might think that other tested devices would have increased their SNR significantly if they had adopted DRE. The already nice SNR numbers of the E1DA 9039S (based on ES9039Q2M), Qudelix 5K (ES9218P) and RME ADI-2 DAC FS (ES9028Q2M) would've become stellar. If DRE can turn an SNR of 85.2 dB into 96.5 dB, it would make those devices' SNR @ 50 mV approach 100 dB!
Definitely true. But ESS, despite having their own DRE technology, chose not to include it in their top DAC chips, not even as an option. It must not be simply because the DAC chips' noise performance is good enough, since ESS would still be interested in improving DAC technology whether the result is beyond the audibility threshold or not. It is because DRE has its inherent limitation as described at the beginning of this review. The Cirrus Logic CS431xx chips showcase an example.
Distortion Performance: DRE On vs. DRE Off​
The Cirrus hump of a CS431xx-based DAC, a distortion phenomenon shown in multitone tests, was described comprehensively in my review. These humps are gone when the Black Pearl is set to NOS and its DRE is disabled:
Note that multitone tests just happen to show part of the DRE artifacts. In fact, DRE's fundamental issue is not with its handling of steady-state test signals---all standard tests we are accustomed to seeing at ASR are based on steady-state signals. By design its problem is with dynamically changing audio content. DRE-induced distortion occurs very often during playback of real audio material, which can be shown by recording it. Actually, very frequent distortions were observed in spectrograms of recordings of my music collection. This does not mean the distortion is clearly audible in all such occurrences. More often than not, it is masked whenever the content's frequency spectrum is wide. I found that the distortion is most noticeable when audio consists of somewhat complex low-frequency signals with not much high-frequency content. The Dune soundtrack clip used in the RAA article is such an example. And an ideal example is the C Major test signal used in Part II of my review. Sill another example is the so-called 'rumble' test clip at the audiocheck website.
Below are the spectrograms of recordings of the Dune soundtrack clip played by the Black Pearl (played at -15 dBFS and normalized to -1 dBFS).
DRE enabled:
This distortion, indicated by vertical lines, is clearly audible as 'crackling' sound.
DRE disabled (in NOS mode):
Distortion is completely gone.
Next are the results of recording the C Major test clip (played at -15 dBFS and normalized to -1 dBFS).
DRE enabled:
The periodic 'clicking' sound from this test clip is very clear, making it an ideal test signal.
DRE disabled:
No hint of distortion.
Lastly, recordings of the rumble test signal (played at -17 dBFS and normalized to -6 dBFS).
DRE enabled:
Crackling is audible.
DRE disabled:
Free of distortion.
Tests of PEQ Performance​
A test of the Black Pearl's PEQ function was performed with the following 5-band filter setting:
To check if it works correctly, its measured response was compared to that of Equalizer APO on Windows 11. To mimic an actual playback situation, periodic white noise was played from foobar2000 and its FFT was captured:
The measured transfer function of the TRN's onboard PEQ (green curve) closely matches that of EQ APO (red curve). There is not even a slight difference. The amplitude difference between the two measurements is not due to a difference in the PEQ setting's preamp gain---they were just separated for comparison. In fact, I found that the Black Pearl's hardware (digital) volume control takes the transfer function's peak into account and does not increase the volume beyond a clipping point.
To see if the onboard PEQ adds any distortion, a 32-tone test was performed:
The quality of the signal through the onboard PEQ is exactly the same as it is through the EQ APO.
Note that the tested PEQ setting consists of only peak filters. Although the app supports shelving filters, they currently do not work. A low-shelf or high-shelf filter is simply interpreted as a peak filter and applied as such. Shelving filters can be convenient, but PEQ with peak filters alone is fine. I personally never used shelving filters. In fact, a PEQ profile used in the second test, shown below, demonstrates that shelving filters' effects can be mimicked by peak filters of negative gain.
Another test was performed with a PEQ setting that I actually use for one of my headphones (Philips SHP9500 modified with leather pads):
All 10 bands were utilized to create this frequency response correction, which is shockingly similar to a headphone target curve of some kind.
Measurements show the TRN's onboard PEQ works correctly:
Again, 32-tone tests indicate its quality is equivalent to EQ APO's:
Conclusion​
This review shows that the TRN Black Pearl in its NOS mode does not exhibit the peculiar distortion behavior associated with CS431xx. A price to pay for having this benefit is to lose some noise performance as DRE is turned off. The 85 dB SNR at 50 mV of the Black Pearl in NOS mode (i.e., with DRE disabled) still represents decent noise performance. In my experience, a signal-to-noise ratio of about 80 dB at 50 mV output is adequate even for sensitive IEMs. At that level, perhaps extremely sensitive IEMs may still produce borderline audible noise. I listened to various tracks from my collection using the Black Pearl connected to the 7Hz x Crinacle Zero:2. I noticed no increased hissing even when cranked up for softly recorded material with DRE off versus on.
Then, why did Cirrus Logic choose to enable DRE by default? Most likely to win the competition. How sweet would it be to proudly tell this tiny low-power chip achieves dynamic range even wider than desktop-grade DACs from ESS and AKM? And such performance was there even with a headphone driver included. Because of their decision, here we're dealing with this Cirrus hump distortion. Good news is that one can disable DRE and eliminate the distortion at least for some devices supporting the NOS mode (tested other devices like the FiiO KA15 and Tanchjim Stargate II). Unfortunately, this hack does not work for other devices with no such option.
The TRN Black Pearl is a budget portable DAC/headphone amp providing excellent output power, low distortion and low noise (even with DRE disabled). It even supports onboard PEQ that works correctly. What more could we ask for at this price?
Sure, there are things to be desired. Audio needs to be resampled on the host side for reconstruction filtering---Windows and UAPP (USB Audio Player Pro) on Android were tested doing this job nicely. I hope someone can contact and convince TRN Audio or TTGK to add a 'DRE off' option that retains standard reconstruction filters, which should be a straightforward firmware revision. Correctly working shelving filters would be nice, too.
New Firmware (V0.3) with Lower DRE Activation Threshold​
WalkPlay/TTGK is another company reacting to the issue of DRE-induced distortion associated with the CS431xx chips! A new firmware release for the TRN Black Pearl, available through its Android app, lowered the DRE activation threshold, a key parameter of DRE operation. With this firmware installed, the Black Pearl does not produce audible distortion caused by DRE while retaining reconstruction filter options. Essentially, this update is identical to what FiiO did for the KA15's new 'DRE Enable' mode: it minimizes DRE artifacts by lowering the threshold for DRE engagement.
Below are the measured noise levels of different firmware options / settings:
Note. To enhance the noise limit of these measurements, E1DA Cosmos Scaler's autoranger was used.
In the new firmware TTGK lowered DRE's activation threshold to -44 dBFS (green solid line) from the original firmware's -12 dBFS (blue solid line) when a reconstruction filter is engaged. As shown in the review, DRE is disabled in the NOS mode (red solid line). That is, DRE is turned on when the signal level is below -44 dBFS when a standard reconstruction filter is selected. This is a very conservative approach and minimizes DRE artifacts. This mode will still increase its dynamic range, by 10 dB, measured with a -60 dBFS tone. Also, it will lower the noise floor when low-level tones (e.g., < -50 dBFS) are played. This is an excellent trade-off.
In case you wonder about SNR at the output of 50 mV:
Condition​
SNR @ 50 mVRMS​
3.5mm out w/ old firmware​
96.5 dB​
3.5mm out w/ new firmware or in NOS mode​
85.2 dB​
4.4mm out w/ old firmware​
93.5 dB​
4.4mm out w/ new firmware or in NOS mode​
82.2 dB​
Note. The lowered DRE threshold makes the SNR @ 50mV same as that in NOS mode because DRE is not active at the 50mV level.
Dynamic range measurements:
Condition​
Dynamic Range​
Maximum Output​
129.3 dB​
2.03 VRMS​
3.5mm out w/ new firmware​
127.4 dB​
2.03 VRMS​
3.5mm out in NOS mode​
117.4 dB​
2.03 VRMS​
132.7 dB​
4.06 VRMS​
4.4mm out w/ new firmware​
130.6 dB​
4.06 VRMS​
4.4mm out in NOS mode​
120.5 dB​
4.06 VRMS​
Note. Channel imbalance was negligible for the above SNR and DR measurements.
Let's see the lowered DRE threshold's effect on distortion. Below are the measurements of total distortion plus noise (TD+N) from 32-tone tests:
With the new firmware, there is still a slight Cirrus hump (green solid line) as the DRE activation threshold is lowered to -44 dBFS. But the signal levels in that hump range are very low, resulting in the distortion much closer to the measurable noise floor. Put another way, this distortion should be inaudible, or nearly indistinguishable from noise (as the noise is unnoticeably low as well). With DRE disabled in NOS mode (blue solid line), even this hump is gone, but as shown in the preceding chart, the noise reduction for lower-level signals will be gone, too.
In the same recording condition as used in my TRN Black Pearl review, the spectrogram of recording of the Dune soundtrack clip (w/ Fast-PC filter) shows no clear distortion:
If you zoom in, you may see very light vertical lines when the signal is decreasing in the later part of the clip. But I could not hear any effect of them in my listening tests. Interestingly, I found that FiiO KA15's new "DRE Enable" mode also shows a tiny hint of DRE artifacts in the same recording when the spectrogram gain is increased, but it is not visible in the same plotting condition. I have no idea why the distortion is slightly higher for the Black Pearl (also shown in the 32-tone test above). But in any case, the level of distortion is too low to be audible.
Recording of the C Major test clip with the new firmware and Fast-PC filter:
Again, if you zoom in, you can see very light vertical lines during transition. But I still couldn't hear these effects.
Recording of Audiocheck's 'rumble' test clip:
Clean.
This new firmware essentially makes the TRN Black Pearl free of audible DRE artifacts while retaining the option of selecting a standard reconstruction filter. It also keeps DRE's low-level noise performance when the signal level is very low (e.g., < -50 dBFS), although there shouldn't be noticeable benefit of this in practice.
We have another CS431xx-based device with no audible DRE artifacts. The TRN Black Pearl, as shown in the review, provides excellent performance as well as 10-band onboard PEQ in a portable form factor. The WalkPlay/TTGK team has been very responsive to my request and feedback in the process of making this update available.
It’s definitely not worth dealing with audible crackling artifacts just for an inaudible improvement in metrics. The noise floor is sufficient for music consumption. For 80d SNR to be problematic, you’d have to listen at ear-bleeding levels, which would cause immediate ear fatigue and tank your listening acuity. In most cases, the noise floor of the music itself is higher anyway, so you'd essentially be engaging in misattribution and audiophilia nervosa.
If anyone is interested in understanding the difference between objective metrics and audibility thresholds, this thread could be helpful: https://www.audiosciencereview.com/...-thresholds-of-amp-and-dac-measurements.5734/
Fascinating audio sleuthing and professional measurements! Brilliant!
I had a feeling before anyone reviewed this that it was going to be quite an awesome dac, especially for the money.
Amazing explanations all around, great job!
Also decent showing of CB1200AU, I expected worse noise performance.
I'm also surprised by the 10-band capability, I thought CB5100 only allowed 8-band EQ? TRN black pearl even announces 8-band in Aliexpress listings, is it a recent firmware update?
In fact, there is a channel imbalance---left channel is somewhat worse, which has been made clear in an edit. I still think the Hi-Max CB1200AU is a great value among cheap dongles.
I don't know. Maybe it was miscommunicated? It must be from the chip's inherent processing capability.
Gorgeous review, thank you for yet another in-depth work!
Now I take a bit of merit for myself since I encouraged you to buy the Black Pearl as soon as it came out (just because I was interested in buying it :p )
Hi-Max is a great value for money but not suited for super sensitive iems, i can hear hissing with TRN MT1 for example. No problem with less sensitive ones like 7Hz Zero.
Right, it was initially disappointing---I even thought it was DOA when not turned on without plugging headphones :p It was an ugly duckling!
Even a decade ago it was difficult to find a headphone amp (or amp stage combined with a dac) that can drive extremely sensitive IEMs without noticeable noise. Now is different. But I still think the Hi-Max's noise performance is acceptable.
Even a decade ago it was difficult to find a headphone amp (or amp stage) that can drive extremely sensitive IEMs without noticeable noise. Now is different. But I still think the Hi-Max's noise performance is acceptable.
Absolutely,
Did you check the "DAC playback volume" default setting on Black Pearl in Walkplay app? Is it set for getting the actual max voltage? As we noticed, Hi-Max comes with it set at 0 that is incorrect, giving only 0.7 V at line level, and setting it a +1 unleashes the actual 1 Vrms. Do Black Pearl needs the same trick?
Absolutely,
No, it does not need a similar trick. Its max output can be obtained in its default setting or 'PURE' EQ.
It's indeed 10-band PEQ. Attached below is from my walk play android app.
Thanks @jkim for the workaround. I can finally hear the dune soundtrack without crackling noise.
OT…
TTGK has released some CB5100 “advanced” FW with support for 10xPEQ, H/L gain, DAC filter selection, Class AB/H (for CS431xx chips). These CBxxx chips may not have a hard-coded limit on the number of PEQ filters. It’s all about the balance between adding more features and keeping stable operations…
  • This review will demonstrate, for the first time, that a CS431xx-based DAC can be completely free of the peculiar distortion associated with the chip, reported at Reference Audio Analyzer , by some audio enthusiasts, and in my previous review. Yes, completely free of the distortion, not even the artifact shown in Part II of the review.
  • The TRN Black Pearl is relatively inexpensive (< $40 at AliExpress) and supports onboard 10-band parametric equalization (PEQ).
Most CS431xx-based DACs measure very similarly to each other. Below is a table of some comparable products:
Tanchjim Space​
Fosi Audio DS2​
Moondrop Dawn Pro​
TRN Black Pearl​
Filter selectionSupportedNot supportedSupported except NOSSupported
One thing I did not quickly figure out about this device is that it is turned on only if one of its output jacks, either 3.5mm or 4.4mm, is occupied by a headphone plug. Otherwise, it is not even recognized by a host device.
Before presenting test results, there is one thing that needs to be made clear. Most modern DACs rely heavily on oversampling (same thing as 'upsampling' in this context) along with an interpolation algorithm to implement a reconstruction filter that removes quantization artifacts. That is, if digital audio content, created at a 44.1 kHz sample rate, is transmitted to a DAC, it is resampled within a DAC and interpolated by its built-in algorithm. When a DAC is set to 'NOS', the signal is supposed to be converted to analog audio without this reconstruction filtering. The consequence is broken soundwaves, shown in measurements as an early high-frequency roll-off and severe ultrasonic distortion. For this reason, when the NOS mode is used, the input signal should be oversampled by the host system. This is a price to pay for disabling DRE in the Black Pearl, or a similar CS431xx-based device supporting the NOS mode. Note that it should be possible to disable only DRE while retaining standard filters in a firmware design---I hear a rumor that a manufacturer is in the process of developing firmware with this option. Fortunately, these days processing power is cheap. Computers and even mobile devices can handle this load without using too much CPU power. In measurements shown below, unless noted otherwise, the Black Pearl was tested in its NOS mode and with input signals resampled at a 192 kHz or 384 kHz sample rate, so not relying on the DAC's oversampling.
Measurement Setup​
Not surprisingly, this DAC is fine with the usual package of measurements using steady test signals (i.e., full-scale multitone, jitter, SMPTE IMD vs. output, and THD+N vs frequency tests). Since these are not the focus of this review, these measurements are shown in thumbnails below:
View attachment 464284View attachment 464285View attachment 464286View attachment 464295
View attachment 464320View attachment 464321
Device​
SNR @ 50 mVRMS​
96.5 dB​
95.9 dB​
E1DA 9039S​
89.9 dB​
87.6 dB​
86.0 dB​
85.2 dB​
Hi-Max CB1200AU​
76.8 dB​
Device​
Dynamic Range​
Maximum Output​
132.7 dB​
4.06 VRMS​
E1DA 9039S​
127.8 dB​
3.49 VRMS​
123.3 dB​
4.10 VRMS​
120.5 dB​
4.06 VRMS​
Hi-Max CB1200AU​
103.3 dB​
1.02 VRMS​
  • It is truly impressive that the E1DA 9039S achieves an SNR of 89.9 dB at 50 mV while having a balanced gain stage providing the maximum output of 3.5 Vrms.
The Cirrus hump of a CS431xx-based DAC, a distortion phenomenon shown in multitone tests, has been described comprehensively in my review. These humps are gone when the Black Pearl is set to NOS and its DRE is disabled:
View attachment 465006View attachment 465005
Note that multitone tests just happen to show part of the DRE artifacts. In fact, DRE's fundamental issue is not with its handling of steady testing signals---all standard tests we are accustomed to seeing at ASR are based on steady signals. By design its problem is with dynamically changing audio content. DRE-induced distortion always occurs during playback of real audio material, which can be shown by recording it. Actually, very frequent distortions were observed in spectrograms of recordings of my music collection. This does not mean the distortion is clearly audible in all such occurrences. More often than not, it is masked whenever the content's frequency spectrum is wide. I found that the distortion is most noticeable when audio consists of somewhat complex low-frequency signals with not much high-frequency content. The Dune soundtrack clip used in the RAA article is such an example. And an ideal example is the C Major test signal used in Part II of my review. Sill another example is the so-called 'rumble' test clip at the audiocheck website.
DRE enabled:
This distortion is clearly audible as 'crackling' sound.
DRE enabled:
DRE disabled:
DRE enabled:
DRE disabled:
Free of distortion.
Conclusion​
This review shows that the TRN Black Pearl in its NOS mode does not exhibit the peculiar distortion behavior associated with CS431xx. A price to pay for having this benefit is to lose some noise performance as DRE is turned off. In my experience, a signal-to-noise ratio of about 80 dB at 50 mV output is adequate even for sensitive IEMs. At that level, perhaps extremely sensitive IEMs may still produce borderline audible noise. The 85 dB SNR at 50 mV of the Black Pearl in NOS mode (i.e., with DRE disabled) still represents decent noise performance. I listened to various tracks from my collection using the Black Pearl and the 7Hz x Crinacle Zero:2. I noticed no increased hiss even when cranked up for softly recorded material with DRE off versus on.
The TRN Black Pearl is a budget DAC/headphone amp combo device providing excellent output power, low distortion and low noise (even with DRE disabled). It even supports onboard PEQ that works correctly. What more could we ask for at this price?
Great recession and great analysis.
If I understand correctly, for optimal performance, DRE would need to be dynamically adapted to the data in real time?
That means the data would need to be analyzed in real time via a buffer, and DRE would need to be adapted accordingly to the data stream?
Does setting nos on the dac and windows usb audio output to 192k/16bit when playing 48k/16bit content perform upsampling interpolation by windows drivers or will it just output 4 times the same values to the usb dac ?
