review of PURIFI "EVAL3" 1ET7040SA ?
Thank you for your in depth post, it’s much appreciated.
I hope as the months and years roll on the delayed wait time is overwritten by the beauty of the unit itself vs the Nord which I think doesn’t look as nice, but that’s me.
How is the bass on two channel fronts only? And the sound stage on the Apollon vs the Denon?
Honestly, in 2 Channel at lower listening levels I didn't notice much difference. Not until you cranked it up did you start to hear a difference. The Purifi 1ET7040SA just remains tighter and controlled all the way up. In fairness, my speakers have integrated powered subs for the very low htz, so that might be masking the lower level Bass differences. Hence this might not be a good comparison to others.
Sound stage is great on both. I would add that it wasn't until I got better main speakers that I actually started enjoying Pure direct 2 channel mode from the Denon. When I was running the B&W 704s as mains with the Denon alone, I actually preferred Stereo mode. Room correction and Audessy adjusting the curves a bit just made them sound better. With the Tritons, they sounded better without all the trickery, albeit they are a lot more expensive speakers!. So I guess it depends on the quality of your main speakers. A neutral amp isn't going to make average speakers sound that much better, unless the speakers power hungry or hard to drive (i.e. impedances dropping below 4-5 olms for a lot of the curve etc). In that case, more power is better.
With the Apollon, I guess it's more what you don't here being so clean/neutral. The Denon adds a slight warm to the music, which I actually didn't mind to much. One subtle difference I've noticed is the Purifi 1ET7040SA are very neutral/clean, so less forgiving on poor recordings. I've become a snob and can't bear listening to some tracks now if they haven't been recorded well lol
Overall I am happy with the purchase. I definitely needed extra amplification as the Denon was running out of puff with 11 channels. If I was still running a 5.1 from the Denon with the Tritons, then that would be a tougher call.
All, you might find these interesting:
The PSU is a Micro-Audio Cobra 1 with Mundorf caps and the OPAMPs are Weiss OP2-BP's.
One more critique. You should not pre-regulate the aux prior to the regulation on the input buffer board. I see that you upgraded the regs on the supply to Sparkos. You should be using unregulated +-18v from the cobra supply to feed the sparko regs in the buffer board. Otherwise you kill the dynamic load response.
What is the +-V output of the aux regs on the Cobra supply?
As the VTV buffer board requires unregulated VAUX, the CN4 and CN6 on the Cobra1 are set to unregulated VAUX which for the Cobra1 is +/-25vdc which is the only choice for the J3 jumper.
Then why would you upgrade the regulators on the Cobra if you’re not even using them?
You can not have enough chassis grounding points and in this case there are 2 provided. In addition, the power cable includes a internal grounding honey comb which is grounded only at the power connector source. The Wago connector is used as a clean way to bridge the connections together. And given that the Wago connector is rated at 660 VAC and 68 Amps there should be no issues.
The ground is only for safety. So if there’s an internal short of the AC wires between the inlet and power supply to the case, the breaker gets tripped. Aluminum is conductive. So if 1 spot on the case bottom is connected to the ground, it’s as grounded as it can get. There is absolutely no advantage doing what you did.
That's a good question. In the future I may use this PSU for different amp which might
The ground is also used to suppress EMI in the power cord as the power cord is wrapped with a copper grounding honey comb which is tied to ground. In addition the chassis ground is used in suppressing any possibility of Ground Loop Hum (sometimes called chassis hum). Hence it may look like overkill but it does not harm to over engineer especially if you have ever have any experience with a Ground Loop Hum in audio equipment.
It won’t cause harm. It’s just a measure that does absolutely nothing. There’s not a single commercial Purifi or Hypex amp on the market that does that. With Purifi or Hypex builds, the grounding is only for safety purposes. It will not affect hum.
First off when I decided to purchase the upgraded PSU I figured it was worth upgrading as many components as possible. Second, even though the VTV buffer board which I like very much does not require regulated power I may decided to change out the buffer board(s). Well if the different buffer board requires regulated power than I am set with really good VR's in the PSU as I have made the complete upgrade.
Any input board without onboard regulation is a flawed design. You want the regulation as close to the load as possible. So any scenario that would require using the Sparko regs on the Cobra supply would be a compromised one. Other than the VDR. In that case I’m not sure what the PSRR, or sensitivity the amp modules have to noise on the VDR line. The Hypex supply certainly does not have squeaky clean VDR power, yet it’s sufficient to allow the Purifi modules to meet advertised objective specs.
Ok, let's be friends. I respect your input and let's get off this subject. However, from an electrical engineering standpoint what I have stated is correct. Let's just leave this subject, Ok?
I posted these pics because I had not seen many samples of the 1ET7040SA amps with the Hypex PSU's and almost none with the Micro-Audio PSU's. I just wanted to share my build with anyone in this forum that wanted to see a finished and working product. It took me a while to find the right combination of pieces and parts to end up with what's in the pics. I can't thank the folks at Purifi, SoundImports, and Ghent Audio enough. And Sami at Micro-Audio was the absolute best to work with on this project.
I am very amiable to sharing what I went thru to complete this project including finding a case that was a good fit and all the modifications I needed to make. For example, and you may have not noticed this but pin 4 on the ribbon cable is completely disabled (cut out), interesting I would think?
All I wanted to do is share what I experienced and learned.
I’m not trying to be confrontational. I’m just pointing out things so others who see the pictures don’t think doing things like that are required for better sound/safety/performance. The build looks very tidy, but that extra grounding step has absolutely no chance of improving anything in any possible way. And the upgrade to the Sparkos for the aux when they will never be used (unless you wanted to downgrade to a new input board that’s a compromised design) were a waste of money.
Other than that great job.
The Marchaudio P501 seems to be the only one so far that has a decent 2x70VDC Powersupply that enables the 1ET7040SA to output there full specs power (?)
@Buckeye Amps does the same (+/- 70V) -> https://www.buckeyeamp.com/shop/p/purifi-1et7040sa-mono-channel-amplifier
and:
Audiophonics just announced their HPA-S500ET class-D amp
(Stereo: 2x purifi 1ET7040SA)
it has a custom 2000W power supply with +/- 70V as well
(I think it's a customized(?) variant of the "SMPS2000RxE V3" but with automatic 110V/220V AC switching from connexelectronic.com)
