@nagster am I reading this measurement right?
The cdj-3000x has a MINUS TEN DB hole with steep slopes at 2000hz?!?!
Yes, the measurements show what you are saying. There was a strange dip in the FR.
Could you perhaps perform your own measurements when you have the chance to use the CDJ-3000X? Especially if the results are unexpectedly good or bad, I do various checks before publishing them, but I cannot say that there is a possibility that the drop in FR is a problem specific to my measurement environment. Having a third party replicate the results would be ideal.
You can verify this using free measurement software (such as REW, MTA, or ARTA/STEPS), a USB flash drive, and a computer equipped with a line input. High-precision equipment is not required. The necessary settings and conditions are detailed in the images I posted. For instance, try comparing amplitudes at frequencies such as 100, 300, 1k, 1.7k, 1.8k, 1.9k, 2k, 2.1k, 2.2k, 3k, and 10 kHz.
I measured two CDJ-3000 units and one CDJ-3000X unit, and all of them yielded similar results. Concerned that there might be an issue with frequency sweeps, I also performed spot measurements, which produced the same outcome. Although I didn't post the data, I verified the CDJ-3000's frequency response using an R&S UPV and a Keithley 2002 before publishing my findings. Since all the instruments showed consistent results, I released the FR data obtained with the APx555. For the CDJ-3000X, however, I did not verify the results with any instrument other than the APx555.
