Sjkrabbe
Thanks Amir - I has been greatly missedAs the title says, the index is back online!!!
I will have to update it with latest reviews but the code is running.
Much appreciate everyone's patience!
Also get rid of smaller font duplicate textOne suggestion is to add some initial text. ”In addition to the index, ASR also contains additional measurements and reviews of devices. These are most easily found using the search function. Tip is to use ”search titles only” and keywords of choice e.g. ”Review CD player”. ”
On a Win11 desktop, using FireFox, I don't get those three horizontal lines:Now it makes sense! It was too well hidden for me. Thanks for pushing my nose into it!
I gotta say, i found it increasingly hard to find reviews even if I know the exact device name. if you search for hd650 review may not result in finding the sennheiser hd650 review because it is maybe named hd 650 or some other minor difference. Now it is really easy.Maybe I am missing something (I am almost certain I will) but what is this good for other than some statics? Almost no links (not even towards the categories) and now a couple of latest review links that can be found using search or the actual review registers too.
Anyway, thanks for the work, I just struggle to find the use case.
Thanks @amirmHi Jens. Thank you for kind words. Yes, I will be updating the index although if someone volunteers to help me, that would be great.![]()
Welcome to ASR !I'm brand new to this forum after reading several reviews it felt unethical not to join. And I'm not complaining, just confirming, the index is not hyperlinked, right? Too much wishful thinking has me tapping my screen like a woodpecker.
Must be some user error (Chrome, Android). Although I should have clarified that there is a small section of what looks like recent reviews. That does work. But for example I can't click the speaker review part that says like "383(!) speakers reviewed" and then see a list of the speakers and click them. Still abnormal?Welcome to ASR !
The 'Review Link' takes me to the review when I click it.
It all works fine.Must be some user error (Chrome, Android). Although I should have clarified that there is a small section of what looks like recent reviews. That does work. But for example I can't click the speaker review part that says like "383(!) speakers reviewed" and then see a list of the speakers and click them. Still abnormal?
