Review Index is Working Again!!!
As the title says, the index is back online!!! :)
I will have to update it with latest reviews but the code is running.
Much appreciate everyone's patience!
I’ve been missing it too. I actually had to find something else to do with my life while it was gone. I’m now bungee jumping, and I’m not sure if that’s a good thing or not. ; )
Thanks for your fix Amir!
Maybe I am missing something (I am almost certain I will) but what is this good for other than some statics? Almost no links (not even towards the categories) and now a couple of latest review links that can be found using search or the actual review registers too.
Anyway, thanks for the work, I just struggle to find the use case.
Click here for awesomeness
Consider adding a link to the thread below to each of the relevant pages of the Master Audio Review Index - for the benefit of new visitors.
Whats the difference? And BTW - thank you very much - the index is a wonderful resource!
Different people at different times worked on the database creating this kind of duplication. Will clean up at some point.
W update on this. Very happy to know this has been generally got back up and running
Whew!! So glad to see this back online. It's hands down the best resource online.
Different people use ASR for different use cases. i will select, say electronics, then ADC and then sort by SINAD. I sort by preference score for speakers and recommended/not recommended.
When a new ASR member asks what DAC they should by, I suggest the sort by SINAD then go down to the price point they like and read reviews.
I will often sort by manufacturer.
That is how I use it.
I missed the burger menu. As stupid as that. See above. My bad.
