Review: Genelec 5.2 nearfield 'digital' system
Mort
System Review
This is a review of my Genelec ‘digital’ nearfield 5.1 audio system. It’s got some features and issues that don’t necessarily come up in a review although Erin has promised to review GLM when he does the 8380a soon. The equipment:
  • 2x Genelec 8361a (10" mains) $11,700
  • 3x Genelec 8341a (6.5" center,surround) $11,025
  • 2x Genelec 7380a (15" sub) $12,790
  • 1x Audiopraise VanityPro Digital AVR $1999 (+AppleTV 99)
  • 1x Genelec 9301a Sub-bass management $1295
I listen in a 10x10 room with the monitors in a slightly isosceles triangle with the coaxial drivers pointed just behind my head. The two 15” subs are distributed on different walls. My MLP is about 4 feet from each main monitor (the surrounds are placed in their proportionate spots slightly behind and in front of me).
The system requires being run with Apple TV, and generally best with Apple Music because of the variety of multichannel content. The system is calibrated with GLM which has a few tricks but is mostly very fast and accurate. The ‘digital’ is that it skips the Genelec ADC conversion.
I listen to pop mostly female artists with a lot of bass, some rock, often at high volume (85-90 db) so I need a lot of bass capacity. 80% of my listening is in multichannel.
Rather than do unboxing or diagrams, I think I just want to cover the pro’s and con’s from my perspective.
Good
  • The Nearfield Direct Soundstage: I have lousy space and still get a clean, low resonance, high direct sound because I’m so close to the monitors. The system is very room independent. It’s got the best clarity I’ve ever heard and a precise ‘3D’ soundstage in 2ch. Sometimes I can’t tell if it’s a vivid ‘3d’ recording or a multichannel mix. You can really hear and place every out of phase effect. The 2ch soundstage isn’t particularly huge compared to a wide directivity speaker, but the definition is amazing. Centered vocal solos hang in space like it’s coming from a ghost. This is a ‘they are here’ feeling, like they are right here in my small room.
  • High Volume: I listen mostly to music with deep bass (electro-pop and adjacent) and I like it loud (85-90db, sometimes 100db). It very clearly plays deep bass tracks like Billie Eilish “Bad Guy” at 101db before hitting the limiter. The best part about the bass volume is the phenomenal sensations and body resonances. It’s not just a chest thump; it’s a whole-body thump like when you are next to a big monitor at a concert.
  • Genelec Systems Integration is great. – SAM/GLM are both very strong and interconnected much like Apple – you just plug and play. I love tweaking my system, but I also like recalibrating quickly and it allows both. To my ear, GLM timing is unmatched, it creates a perfectly solid center in 2ch and a very neutral FR. It’s especially good with a SAM subwoofer. GLM is strongest in my opinion integrating subs.
  • Accessories and mounting are great. Almost all Genelec home monitors are table, floor, wall and ceiling mountable. Sometimes they look great and sometimes not but they are all expensive for what they are. Still, if you like this look where the monitor is mounted to the wall Genelec is your friend. Only my rear speakers are mounted, the front are on stands. Studio Accessories – A special appreciation for the heavy wired volume control dial. It is a joy to manage SPL with that device.
  • Sturdy AF - They are built like tanks, are supported for a long time and retain their value (not as much as some sellers think) for a long time. Base Warranty is 5 years. Email Support is awesome. I buy used almost exclusively and have never had an issue. Yes, the 70lb 8361a main is a beast to carry but only the 7380a subwoofer at 105lbs required two to carry and it’s got good handles.
  • DSP w/GLM is excellent - I’ve worked with Audyssey, DiracLive, Wiim, REW and DiracART and none are as fast or accurate at applying enough DSP (mostly cuts, but a few boosts) to get a very flat ‘anechoic’ response. The GRADE report gives tons of useful information. I assume Genelec can do this magic because they have control over the whole system.
Bad
  • Nearfield issues – there is a bit of the “head in the vice” effect. Sometimes small shifts can affect the sound because I’m so close. I can watch TV and read in my MLP without anything audible but if I move around a lot it’s very noticeable.
  • GLM quirks – GLM allows only a -3db shelf to bass registers, which isn’t enough to my taste. GLM residing on PC can make volume control glitchy when PC is off.
  • Not good for larger rooms – I don’t like them as much for larger rooms. They are too dry to my taste. I love this system but for a larger space and especially one with other people, I much prefer a wide directivity system like my Philharmonic Audio.
  • Digital is overrated. This is considered a ‘digital’ system because it’s digital all the way to the DAC and it skips the analog to digital step. This in theory is cleaner but it’s probably not audible. What IS audible are the *cking Apple TV digital audible artifacts like pops and tracks starting briefly at high volume. Add to that, the equipment is more limited than analog and it’s also more expensive. I’m over ‘digital’
  • Looks –Meh, I think they are good enough but agree they are not for everywhere.
  • Cost - $38,908 plus tax and maybe shipping new here in the USA makes the cost of a new car, so enjoy it gents. I listen to mine for hours every day and hate to drive.
  • Cables – I don’t think it could be smaller than my 10x10 room. It’s a lot of fucking cables.
Stupid Q how do you actually integrate these speakers with an Apple TV or any digital source ? An AVR or some other box ? :)
Not stupid at all. That's what the Vanity Pro and 9301a do together, basically a digital AVR with only one input.
Where did you hide the second subwoofer?
System Review
Good
Bad
Thank you for sharing your experience.
Helps a lot to where the endgame solution ultimately leads.
Regarding wide directivity in bigger rooms, that is my preference too, so I can relate to that. Makes sense too when you think about it: wide directivity means all people on the couch can enjoy the music or movie. (Ime and imo)
One thing that puzzles me about your pictures is the seating position. Isn't it detrimental to the sound to sit that close to the rear wall? I would have thought that placing the listening seat at least 3 feet in the room and the front speakers closer to the front wall would give a better sound.
Actually I got it after those pics were taken. I kind of regret it. I was hoping for something that would improve my FR but could not find an arrangement that was better than one sub. It goes louder of course but I didn't want to pay $4k for +3db
Good
Bad
Thanks for sharing your system details and experience.
In the above comments, I wonder if you tried a wider speaker spacing to increase the percentage of reverberant sound at the MLP?
Personally I am not a fan of nearfield listening for musical enjoyment. The soundstage just has this miniature facsimile of the real thing quality about it and while I appreciate it’s the best way to hear the recording’s properties, it lacks immersion and scale.
Someone else already made this comment but I too was wondering about the MLP proximity to the back wall and, again, if you experimented with positioning?
A wonderful system though. I can’t imagine you could improve on it in terms of resolution and transparency.
Maybe try 4 subs ;)
One more thing that is neither bad nor good, but i expected to hate it is using apple music via the TV app. It means that a screen is on for all my viewing and I have the apple remote only (no phone app) to handle the music. Apple Music imported my many playlists with little difficulty and I kind of like the screen like a monitor for listening.
Lysoniq is one option, but you may need to dedicate one (old?) iphone or ipad to it. Then you can use either phone or apple tv (or mac) to control it. It is not just roses, but worth to check if you haven’t already.
Then plugin that old ipad to eitr 2 and you get aes to genelecs, with loudness compensated volume. You can of course also use glm for volume, but that does not implement loudness compensation.
Personally I think there is something extra to listen music in a pitch black room.
Why not control the AppleTV via iPad?
It's actually more clumsy, takes several clicks to attach it each time. I don't use the ipad for anything else so it's not good for me.
I've had a similar set up for a few years now. Couldn't be happier with it
Not trying to bug you but are you sure main part of your "Bad(s)" (# 1-4) is due to choice of gear and not due to your setup? You are exposed to a very diffuse sound field with all the reflections causing comb filtering and what not all; causing audible differences with the slightest movements. This is not the Genelecs' directivit itself or your too close seating position (apart from the two rear monitors maybe; these nearly look like headphones^^).
How is the Apple TV connected? I just recently installed an Apple TV 4K connected like this (+ Ethernet) and have 0 issues. Pops etc. usually indicate package loss and this is mostly a WiFi(!) - or router firewall issue, as well as might be caused by processing delays or general bandwidth limitation.
It's not about digital vs. analog IMO but rather on which signal path makes it easier to manage everything on the specific installation. One could also combine both and not get any audible degradation, as long as ADC and DAC stages are impeccable.
Yes, I also prefer wide(r) horizontal directivities but this always comes at the cost of imaging; especially when early reflections are not being treated and this the worst, when the room is rather narrow.
