EU model A2155 (0,5V)
US/ Intl (hopefully full 1v) A2049
Unless there has been revisions of course
Those are USB-C models. The lightning USA version is A1749. Dunno about the EU version
My bad- didnt check back on the thread I was replying to- just went by thread title and the last post.Those are USB-C models. The lightning USA version is A1749. Dunno about the EU version
What?? So basically the stupid Europeans (like me) have to protect their hearing by force by not listening loud enough and the Americans can go fuck up their hearing as much as they like? That is not fair!No.
Lightning to 3.5mm dongle has also different model numbers (US and EU) and they both deliver 1 Vrms when hooked to an iPad or a non EU iPhone. And 0'5 when hooked to an EU iPhone.
I have both dongles and have tested them.
Dunno see why USB-C dongle should be different.
Host rules the Vrms output. Not the dongle.
The Apple website is now so streamlined it doesnt even tell you model number/ specs! For the USB C the "specs" areThose are USB-C models. The lightning USA version is A1749. Dunno about the EU version
Ridiculous. They could have written: 'It´s a thing. Plug in your headphone and don´t make stupid question'.The Apple website is now so streamlined it doesnt even tell you model number/ specs! For the USB C the "specs" are
What model number is printed on the wire of your dongle?Maybe it is this, I bought it in Germany, is there a way to check this (without measuring) ?
Where is that in iOS?
Thanks, but that is Bluetooth. We are discussing the Lightning headphone adapter.Hi, this is what you do.
Go to Settings -> Bluetooth
Look at 'MY DEVICES'.
To the right of the device name there's a blue 'i' in a blue circle.
Click on the 'i'. You'll get a list of device types - choose between them.
By the way, that list of device types only appears if and when the device is connected.
Best wishes.
The Lightning adapter that Ken Rockwell tested, presumably the USA version, is model A1749. Mine, bought in the UK, is also A1749. <https://www.kenrockwell.com/apple/lightning-adapter-audio-quality.htm>What?? So basically the stupid Europeans (like me) have to protect their hearing by force by not listening loud enough and the Americans can go fuck up their hearing as much as they like? That is not fair!
I've just put some 1 kHz sine test files on my UK iPhone Xs and tested the Lightning adapter (UK A1749) output with the volume at max. I gotAt least with the Type-C version, the UK gets the same 0.5Vrms limited version as the EU:
Is this something to do with a DMM's AC response, and is the difference enough to make it worth repeating the test with 60 Hz? I used 1 kHz because this is pretty much the audio standard.use a 60Hz test file for more accurate readings with multimeters
Yes. They're most accurate at 50/60HzIs this something to do with a DMM's AC response
eh, probably not. With a 0dBFS test file at 100% volume you should see 0.501Vrms or thereabout.is the difference enough to make it worth repeating the test with 60 Hz?
Modern DACs are flat to <20Hz, so there's nothing to worry about when using 60Hz instead of 1KI used 1 kHz because this is pretty much the audio standard.
So what was Ken Rockwell testing?Yes. They're most accurate at 50/60Hz
Oh and the A1749 is for sure a EU model with that 0.5Vrms hardware limiter, which means there's no additional software limiter in iOS.
Ah shoot, my bad.So what was Ken Rockwell testing?
That's not true. Both the American Lightning dongle (AM) and the European one (ZM) share the same model designation A1749.Oh and the A1749 is for sure a EU model with that 0.5Vrms hardware limiter
Thanks. At last that makes sense, although it's odd that the USB-C adapters have different model numbers and the Lightning ones don't. BTW where did you find this out?Ah shoot, my bad.
So both Ken Rockwell and RAA tested the AM A1749 with 1Vrms, while you got the ZM A1749 with the limiter.
View attachment 215755 View attachment 215756
I'd suggest the higher output is useful if it's to be used as a dac with line out. My current EU USB C version is too quiet used that way. Hoping to try the US version soon...What?? So basically the stupid Europeans (like me) have to protect their hearing by force by not listening loud enough and the Americans can go fuck up their hearing as much as they like? That is not fair!
