Thanks for that. I'll have to reacquaint myself with how to SSH into the RPi so I can open a terminal to run alsamixer and follow these steps: https://wiki.ubuntu.com/Audio/Alsamixer
Correct?
Correct?
Correct.Thanks for that. I'll have to reacquaint myself with how to SSH into the RPi so I can open a terminal to run alsamixer and follow these steps: https://wiki.ubuntu.com/Audio/Alsamixer
Correct?
A2049:Do you guys know what version of the Apple adapter is being sold in Japan?
Thanks, StaticV3!
Great, thanks!That's the same one you get from Amazon in the U.S. @bezae welcome to the forum. Where are you located?
Great, thanks!
I'm based in London, UK, and have been lurking on this forum for years. ASR remains my main source for hi-fi reviews, as I appreciate Amirm's scientific approach over reviews filled with pseudo-acoustic jargon. Excited to finally join the conversation!
% of voltage?Can someone confirm this regarding gain levels?
Code:PC EU 50% US 100% Android EU 13% US 25% Android w/ 3rd-party SW EU 45% US 90%
Yes assuming 100% is 1V.% of voltage?
In a nutshell:Can someone confirm this regarding gain levels?
A2049 | A2155 | |
Bit-perfect playback w/ UAC2 control | Reference | -5.8 |
PC Default | -0 | -5.8 |
Lineage OS 21 default | -21.5 | -27.3 |
Lineage OS 21 UAC2 maxed | -1.5 | -7.3 |
Oxygen OS 11 default | -21.4 | -27.2 |
Oxygen OS 11 UAC2 maxed | -1.4 | -7.2 |
OneUI 3.1 default | -20 | -25.8 |
OneUI 3.1 UAC2 maxed | -0 | -5.8 |
A2049 | A2155 | |
Bit-perfect playback w/ UAC2 control | 100% | 51% |
PC Default | 100% | 51% |
Lineage OS 21 default | 9% | 4% |
Lineage OS 21 UAC2 maxed | 84% | 43% |
Oxygen OS 11 default | 9% | 4% |
Oxygen OS 11 UAC2 maxed | 85% | 44% |
OneUI 3.1 default | 10% | 5% |
OneUI 3.1 UAC2 maxed | 100% | 51% |
A2049 | A2155 | |
Bit-perfect playback w/ UAC2 control | 100% | 67% |
PC Default | 100% | 67% |
Lineage OS 21 default | 23% | 15% |
Lineage OS 21 UAC2 maxed | 90% | 60% |
Oxygen OS 11 default | 23% | 15% |
Oxygen OS 11 UAC2 maxed | 91% | 61% |
OneUI 3.1 default | 25% | 17% |
OneUI 3.1 UAC2 maxed | 100% | 67% |
"Switching to high-impedance 300 ohm Sennheiser HD-650 nearly killed performance. The sound was OK but bass is week and dynamic range just not there. Here my reference is more powerful desktop and battery operated portables."
Below 20Ω load impedance, the US dongle can clip hard when pushed to 100%, which can result in poor sound.Couple of questions, using the Apple dongle as long as the volume is loud enough your headphone is being powered to it maximum capability, Bass impact/control for example will not be improved on an amplifier with higher voltage/current at the same volume level?
If you have the EU dongle, or headphones above 20Ω impedance, and you're happy with the volume you're getting out of it, then no money spent on a beefy external headphone Amp will increase impact, control, slam, dynamics at the same volume.
To actually increase these things, you'd have to turn up the volume or use DSP.
Bass is weak due to how human ears perceive low volume (equal loudness contours) and dynamic range is not there because volume is low (compared to external Amps).he talks about exactly which you say shouldn't be effected, "bass is weak and dynamic range just not there"
If you were to match volume on an external Amp to the Apple dongle and record the HD600 from both the external Amp and the Apple dongle, the result would be identical.
