Ataraxia
- Joined
- Sep 22, 2019
- Messages
- 136
- Likes
- 76
Keep in mind that AVRs (and related integrated 2 channel amp such as Yamaha's A-S801) can have two separate DACs for different inputs. As far as I know, for HDMI inputs, the main and better DACs such as the AK4458 and ES9006 are used.
If you use the front USB input, Ethernet (network streaming), or even optical and coax, then all bets are off and the signal may be routed through the lower grade DACs such as the PCM5100 or the slightly better PCM5101 in the integrated amp such as the Yamaha A-S801. For Z2/Z3, chance is good that the lesser DAC would be used, such as the case for D&M, Onkyo and Yamaha's.
In some cases, such as Yamaha's, even for the main zone, they would use two different ones, the better DAC for the main 7 channels and a slightly lower grade one for the remaining channels. For example: the flag ship RX-A3080 has the Sabre ES9026 Pro for the main 7 channels, and the ES9007S (same as the 9006) for the remaining channels, and then mostly the PCM5101 for the Z2/3. 3 different DACs!! It's all about cost, I assume..
Thanks for the detailed response. What I know is streaming Tidal hi-fi sounds extremely good and the USB input with FLAC sounds noticeably better, especially with 24/48+ recordings. I of course assumed I am using the ESS DAC's (dual in the A2080). That's the only one they market in the main description. If I'm not using the better DAC chip with streaming and USB I don't know what to say other than I'm loving the audio quality with Tidal Hi-Fi and USB FLAC. I did try a CD one time just for kicks from an old Sony DVD player optical to the A2080 and it was not even close to Tidal hi-fi and USB FLAC.
This thread piques my interest because if my AVR isn't a very good hi-fi amp I wold really like to buy a better on for 2-channel.
